    Cinema 4D R20 (20026) GeDialog.SetLong, SetInt32 OverflowError
    r20python
    7 Posts 3 Posters 2.6k Views 2 Watching
    • mikeudinM Offline
      mikeudin
      Hello guys!
      Working on updating plugins for C4D R20.
      Have an error: "OverflowError: unsigned byte integer is greater than maximum" when trying to update Tool plugin interface EditNumberArrows field with numbers greater then 255 (there is no error if number less or equal then 255) using commang
      GeDialog.SetInt32(0001,int(var),min=0, max=c4d.MAXLONGl, step=1, tristate=False, min2=0, max2=c4d.MAXLONGl)
      or
      GeDialog.SetLong(0001,int(var),min=0, max=c4d.MAXLONGl, step=1, tristate=False, min2=0, max2=c4d.MAXLONGl)
      On C4D R19 it works fine...
      https://mikeudin.net
        mp5gosu
        See here: https://developers.maxon.net/docs/cpp/2023_2/page_list_of_name_changes_in_r15_api.html
        There has probably changed more than the names only.
        mikeudinM 1 Reply Last reply Reply Quote 0
        • mikeudinM Offline
          mikeudin @mp5gosu
          @mp5gosu thanks for your reply, but this error appears also with new names like SetInt32
            mp5gosu
            Oh, didn't notice you're working with python. I'll take a look into it later.
              mp5gosu
              Hey there,
              I tried to replicate you issue but wasn't able to.
              Here's some code I used and everything works as expected:
              from c4d import gui
              var = float(2520.023)
              class myDlg(gui.GeDialog):
                  def Execute(doc):
                      print "Hi"
                      return true
                  def CreateLayout(self):
                      self.AddEditNumberArrows(1001, c4d.BFH_SCALEFIT | c4d.BFH_SCALEFIT, initw=70, inith=40 )
                  def InitValues(self):
                      self.SetInt32(1001,int(var),min=0, max=c4d.MAXLONGl, step=1, tristate=False, min2=0, max2=c4d.MAXLONGl)
                  dlg = myDlg()
                  dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=1050902, defaultw=400, defaulth=32)
              I have some questions about your code:
              • what type is var of?
              • when are you calling your code to set the parameters?
              • does it also happen when you replace (int)var with a hardcoded value?
              Robert
              • Y Offline
                y_puech
                The OverFlow error is thrown when SetInt32() is called from a SubDialog (used for Tool plugins settings).
                I'm afraid a regression was introduced in R20. It will be fixed in the next update.
                The workaround in R20 is to perform in Python what GeDialog::SetInt32() does in the C++ API (see cinema.framework/source/c4d_gui.cpp).
                import sys
                def StringToID(str):
                  return int('0x'+hex(ord(str[0]))[2:4]+hex(ord(str[1]))[2:4]+hex(ord(str[2]))[2:4]+hex(ord(str[3]))[2:4], 16)
                CM_TYPE_INT = StringToID('vint')
                CM_VALUE_VAL = StringToID('valu')
                CM_VALUE_FORMAT = StringToID('frmt')
                CM_VALUE_MIN = StringToID('mini')
                CM_VALUE_MAX = StringToID('maxi')
                CM_VALUE_MIN2 = StringToID('min2')
                CM_VALUE_MAX2 = StringToID('max2')
                CM_VALUE_STEP = StringToID('step')
                CM_VALUE_TRISTATE = StringToID('tris')
                def SetInt32(dlg, id, value, min=-sys.maxint-1, max=sys.maxint, step=1, tristate=0, min2=-sys.maxint-1, max2=sys.maxint):
                  msg = c4d.BaseContainer(CM_TYPE_INT)
                  msg[CM_VALUE_VAL] = value
                  msg[CM_VALUE_FORMAT] = c4d.FORMAT_INT
                  msg[CM_VALUE_MIN] = min
                  msg[CM_VALUE_MAX] = max
                  msg[CM_VALUE_STEP] = step
                  msg[CM_VALUE_TRISTATE] = tristate
                  if min2 != -sys.maxint-1 or max2 != sys.maxint:
                    msg[CM_VALUE_MIN2] = min2
                    msg[CM_VALUE_MAX2] = max2
                  return dlg.SendMessage(id, msg) != 0
                Call this SetInt32() from the subdialog to initialize any integer value.
                Note c4d.MINLONGl and c4d.MAXLONGl are no longer used internally. The documentation has to be updated.
                Former MAXON SDK Engineer
                • Y Offline
                  y_puech
                  Hi @mikeudin,
                  I'm wondering if your question has been answered. If so, please mark this thread as solved.
                  Yannick
