    Error with SetPrimitiveType
    9 Posts 0 Posters 1.0k Views
      On 29/04/2003 at 22:09, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:      Mac OSX  ;
      I have a very simple coffee plugin that worked under 7.3 but in 8.1 gives an error in the following (partial code) :
      var cube = new(PrimitiveObject);
      cube->SetPrimitiveType(PRIMITIVE_CUBE);
      The error is:
      Incompatible types... NIL/OBJECT
      What could be wrong? Has something changed in 8.1?
        On 29/04/2003 at 23:19, xxxxxxxx wrote:
        On further exploration I see that
        returns nil
        It PrimitiveObject not in the api anymore? How does one make a cube?
          On 30/04/2003 at 02:31, xxxxxxxx wrote:
          This is the only place where the R8 C.O.F.F.E.E. actually has changed. Since PrimitiveObject doesn't exist anymore you have to use the new CubeObject class. Please refer to the C4D executable with a hex editor for the rest of the classes.
            On 30/04/2003 at 07:41, xxxxxxxx wrote:
            Thanks Mikael - That worked! Only one thing seems to still be not working as it did in v 7.3:
            var floor_instance = new(InstanceObject);
            var ic = floor_instance->GetContainer();
            ic->SetData(INSTANCEOBJECT_SOURCE,"hausfloor");
            creates the instance, but does not give it the source object, though "hausfloor" exists
              On 30/04/2003 at 08:19, xxxxxxxx wrote:
              This part (object links) doesn't work in C.O.F.F.E.E. yet. So you cannot change what a created instance object points to.
                On 30/04/2003 at 08:38, xxxxxxxx wrote:
                So can I simply not use Instances in coffee then? Or is there someway to create an instance and point it at the same time? With arguments in the new command?
                  On 30/04/2003 at 10:44, xxxxxxxx wrote:
                  No, unfortunately that's not possible.
                    On 18/09/2004 at 16:51, xxxxxxxx wrote:
                    This post helped me to resolve a problem but I've got to ask, did Maxon ever produce an updated COFFEE SDK?  I've got the latest SDK from this site but it still refers to the defunct PrimitiveObject which doesn't work in 8.1+.
                    Mikael states in this thread:  "Please refer to the C4D executable with a hex editor for the rest of the classes."
                    Surely we can do better than that, right Maxon?
                    In a another post by a similarly frustrated COFFEE coder, Mikael responds: "I'm glad that you found the solution. As you've noticed the C.O.F.F.E.E. docs are currently for R6. The reason for this is mostly that besides the things you noticed there haven't been many changes to C.O.F.F.E.E. in R8."
                    May I suggest that since so little has changed, it wouldn't take much effort to actually update the SDK.  It would be of great value to those stubbing their noses on the walls of these so-called minor changes if we didn't have to learn COFFEE -and- what's wrong with the SDK documentation.  Remember that not all of us have been following Cinem4D from 6.x on.  I personally came in at 8.5 with an implicit trust of the documentation that Maxon is providing.
                    Thank you Mikael (and others) for your insight on these issues.  If it weren't for your posts, I'd still be stuck!
                      On 20/09/2004 at 10:40, xxxxxxxx wrote:
                      This work fine in R8 .
                      ic->SetData(1001, hausfloor);
                      floor_instance->SetContainer(ic);
                      hausfloor is an Object, not name of Object.
