    Bug in Python R20 [c4d.MDATA_EXTRUDE_PRESERVEGROUPS]
    pythonr20
    3 Posts 2 Posters 1.8k Views
    • Caleidos4DC Offline
      Caleidos4D
      Hi!
      sorry for my bad english
      I found this strange behavior in the Extrude tool:
      from c4d import gui, utils
      	#Estrusioni
      	settings = c4d.BaseContainer()
      	settings[c4d.MDATA_EXTRUDE_OFFSET] = 20
      	settings[c4d.MDATA_EXTRUDE_CREATECAPS] = False
      	settings[c4d.MDATA_EXTRUDE_SUBDIVISION] = 0
      	settings[c4d.MDATA_EXTRUDE_PRESERVEGROUPS]=True
      	utils.SendModelingCommand(command = c4d.ID_MODELING_EXTRUDE_TOOL,list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings,doc = doc, flags=c4d.MODELINGCOMMANDFLAGS_CREATEUNDO)
      [c4d.MDATA_EXTRUDE_PRESERVEGROUPS]=True is always False
      • a_blockA Offline
        a_block
        as described in the user help for the Extrude, Preserve Groups works in combination with the Maximum Angle parameter. So you also need to set MDATA_EXTRUDE_ANGLE for it to work.
        Andreas
          Caleidos4D
          Now Work
          Thanks Andreas
