    RemoveUserData does not fully remove User Data
    4 Posts 2 Posters 1.9k Views 1 Watching
    • D Offline
      dmp
      If I add a string field with AddUserData.
      And then I delete that string field with DeleteUserData.
      And then try to add a float field with AddUser Data:
      I get
      TypeError: setitem expected str, not float
      And if I try to get the value before EventAdd, I get the old, deleted value
      Anyone know any workarounds? Like how to flush the memory of the user data?
      • D Offline
        dmp
        Here's a simple test to run in the script editor:
        Add a Cube to the scene.
        current_doc = c4d.documents.GetActiveDocument()
        cube = current_doc.SearchObject('Cube')
        def AddStringDataType(obj):
          if obj is None: return
          bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_STRING)
          bc[c4d.DESC_NAME] = "String"
          element = obj.AddUserData(bc)
          obj[element] = 'bob'
        def AddFloatDataType(obj):
          bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_REAL)
          bc[c4d.DESC_NAME] = "Float"
          obj[element] = 22.2
        AddStringDataType(cube)
        cube.RemoveUserData(1)
        AddFloatDataType(cube)
        • Y Offline
          y_puech
          Even if a user data parameter is removed its data is still stored. And when [] operator is used, the Python API layer checks the type of a parameter before setting its data.
          The solution is to use del() passing the parameter data to clear its type and value. Then the parameter can be set any data.
          Here is how I modified the script you posted:
          def AddUserData(obj, dtype, name):
              # Retrieves default user data container for the passed type
              bc = c4d.GetCustomDataTypeDefault(dtype)
              bc[c4d.DESC_NAME] = name
              # Adds the user data
              # Returns the user data description ID
              return element
              # Searches for 'Cube' object
              cube = doc.SearchObject('Cube')
              if cube is None:
              # Adds string user data
              dataID = AddUserData(cube, c4d.DTYPE_STRING, "String")
              cube[dataID] = 'bob'
              # Removes user data
              cube.RemoveUserData(dataID)
              # Clears user data type and value
              del(cube[dataID])
              # Adds float user data
              dataID = AddUserData(cube, c4d.DTYPE_REAL, "Float")
              cube[dataID] = 22.2
              # Updates Cinema
          Note it's recommended to use main() like in the default script. Also when Cinema 4D runs scripts doc is the active document (op is the active object).
          Former MAXON SDK Engineer
          • D Offline
            dmp
            This worked. Thank you.
