    Issue Changing Modeling Axis
    pythonr20
    3 Posts 2 Posters 1.9k Views 1 Watching
    • D Offline
      DavidW
      I'm trying to convert a working COFFEE script for changing the modeling axis to Python. Updated tool data is printed to the Console but the Axis parameter is not changing.
          tool_dat = doc.GetActiveToolData()
          tool_dat[c4d.MDATA_AXIS_MODE] = c4d.MDATA_AXIS_MODE_FREE
      • Y Offline
        y_puech
        The script you posted does work with for instance the Live Selection tool but does not work with Move/Scale/Rotate tools.
        The following script changes the MDATA_AXIS_MODE to MDATA_AXIS_MODE_FREE for any active tool:
        from c4d import plugins
        def SetToolData(doc, toolID, paramID, data):
            plug = plugins.FindPlugin(toolID, c4d.PLUGINTYPE_TOOL)
            if plug is None:
            plug[paramID] = data
            SetToolData(doc, doc.GetAction(), c4d.MDATA_AXIS_MODE, c4d.MDATA_AXIS_MODE_FREE)
        The above script does not use GetActiveToolData(). It retrieves the object for the active tool (with FindPlugin()) and sets the parameter (with operator []).
        For some technical reason, several tools need their settings to be changed via parameters and not accessing the tool data container directly.
        Best regards,
        Yannick
        Former MAXON SDK Engineer
        • D Offline
          DavidW
          Thanks for the solution and explanation Yannick. It's working perfectly now and I can finish converting my scripts.
