    Dialog size
    4 Posts 0 Posters 1.9k Views
      On 28/08/2018 at 01:33, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hello.
      I have a resizable dialog and I need to know its width and height.
      Is there a way to do it in Message method listening to BFM_SIZED ?
      In general, how else can I know its size ?
      Thank you.
      Petros.
        On 29/08/2018 at 00:44, xxxxxxxx wrote:
        Hi Petros,
        maybe take a look at the GetItemDim() function. You could call it on your parent dialog group - might get what you're after?
        WP.
          On 29/08/2018 at 04:48, xxxxxxxx wrote:
          Hello.
          GetItemDim() works fine ! It returns the size of the requested ID.
          There is another problem though if used in Message listening to BFM_SIZED.
          If I double click the Dialog's Title bar causing the dialog to be maximized, it returns the previous width (not the maximized one).
          So it appears that BFM_SIZED is not the right message to use in order to retrieve the correct Param width. I need the size after the resizing.
          Thank you.
            On 30/08/2018 at 09:05, xxxxxxxx wrote:
            Hi Peterakos,
            Sorry for the delay, even if it's marked as private you can use BFM_ADJUSTSIZE as bellow to know the current size of the windows.
            Int32 YourGeDialog::Message(const BaseContainer& msg, BaseContainer& result)
            	switch (msg.GetId())
            		case BFM_ADJUSTSIZE:
            				Int32 w = msg.GetInt32(BFM_ADJUSTSIZE_WIDTH);
            				Int32 h = msg.GetInt32(BFM_ADJUSTSIZE_HEIGHT);
            				break;
            	return GeDialog::Message(msg, result);
            If you have any questions, please let me know.
            Maxime!
