    find material slot for shader
    3 Posts 0 Posters 2.1k Views
      On 26/08/2018 at 07:20, xxxxxxxx wrote:
      hi there,
      is it possible to find the shader slot in a material for a given shader?
      i.e. if i have this setup
      Mat[c4d.MATERIAL_USE_COLOR] = some_shader
      can i find c4d.MATERIAL_USE_COLOR if i have only Mat and some_shader?
      --> I'd need something like:
      findSlot(Mat, some_shader)  # 2000 (c4d.MATERIAL_USE_COLOR)
      best, index
        On 27/08/2018 at 11:29, xxxxxxxx wrote:
        Hi index,
        Unfortunately no, there is no such function. If the shader setup is simple enough, you could just have an array with parameter IDs and then compare the linked shaders in your own FindSlot() function. A bit more complicated it gets, if the shader setups can be more complicated, including sub-shaders, like e.g. layer shader. Then you have to additionally iterate the shader tree for each slot.
          On 28/08/2018 at 02:22, xxxxxxxx wrote:
          tx andreas, an exciting world 🙂
          i got a bit further with my findSlot(Mat, some_shader)
          and dont understand why i get Attribute Errors when i iterate over a bc:
          def findSlot_v1(sh) : # sh = some shader already inserted in a material slot
          bc = mat.GetDataInstance()
          for i, v in bc:
          print i, v
          if v == sh: return i
          --> AttributeError: Parameter value not accessible (object unknown in Python)
          def findSlot_v2(sh) : # sh = some shader already inserted in a material slot
          for i, v in bc:
          try:
          except AttributeError:
          pass
          def findSlot_v3(sh) : # sh = some shader already inserted in a material slot
          for i in range(len(bc) - 1) :
          try:
          index = bc.GetIndexId(i)
          if op[index] == sh: return index
          pass
          --> this finally works
          but could anybody tell me why i get these strange AttributeErrors ?
          the first version is straight from the book:
          https://developers.maxon.net/docs/py/2023_2/modules/c4d/BaseContainer/index.html?highlight=basecontainer#BaseContainer.\__iter\_\_
          and... i guess there no nicer/faster solution without iterating over the complete bc?
          best, index
