    Convert 3D space to 2D Space
    6 Posts 0 Posters 1.6k Views
      On 04/07/2018 at 03:36, xxxxxxxx wrote:
      Hey Everyone,
      Just wanted to know if anyone can point me in the right direction.
      Im looking to convert a 3D (world) space, point co-ordinate into a 2D camera space co-ordinate.
      Is this possible with the python SDK?
      Any info or a nudge in the right direction is much appreciated!
      Cerac
        On 04/07/2018 at 12:22, xxxxxxxx wrote:
        Check out the BaseView class
        BaseView::WC() or BaseView::WC_V() is what you most likely are looking for.
          On 05/07/2018 at 02:12, xxxxxxxx wrote:
          Hi Ceracticus,
          As Daniel already pointed you BaseView.WC and BaseView.WC_V is the way to go.
          Additionally, I would like to point you to the C++ manual which can give you some valuable information even for python.
          Maxime
            On 05/07/2018 at 09:53, xxxxxxxx wrote:
            Hey Both,
            thanks so much for your suggestions, massively helpful.
            Managed to get 90% of the way with looking up other examples on this site, plus your feedback which is really great.
            What im essentially doing is rebuilding the interactive render region crop function out of guides (converted from world to screen space) then plugging these values into the active render setting.
            Ive got everything working as expected - apart from when a camera has film offset. I know i can access this data which is great.
            [c4d.CAMERAOBJECT_FILM_OFFSET_Y]``` [c4d.CAMERAOBJECT_FILM_OFFSET_X]`
            Does anyone know what the best way of taking this into account whilst running my code?
              rd = doc.GetActiveRenderData()
              rd_w = rd[c4d.RDATA_XRES_VIRTUAL]
              rd_h = rd[c4d.RDATA_YRES_VIRTUAL]
              bd = doc.GetActiveBaseDraw()       # Get current view
              sf = bd.GetSafeFrame() #SafeFrame
              obj = op.GetObject()               # Get Null
              cam = obj[c4d.ID_USERDATA,2]       # Get Camera
              top = obj[c4d.ID_USERDATA,3]       # GetGuideObjects
              bottom = obj[c4d.ID_USERDATA,7]
              left = obj[c4d.ID_USERDATA,8]
              right = obj[c4d.ID_USERDATA,9]
              switch = obj[c4d.ID_USERDATA,4]           # Get Switch
              cZ = cam[c4d.CAMERAOBJECT_TARGETDISTANCE] #z-distance
              if switch:
                  # +-------------------------- TOP IRR
                  topPos = top.GetMg().off #top global position
                  top_v = bd.WS(topPos) #World2Screen
                  top_v[0] = (top_v[0] - sf["cl"])/(sf["cr"]-sf["cl"])
                  top_v[1] = (top_v[1] - sf["ct"])/(sf["cb"]-sf["ct"])
                  top_v[2] = (cZ-top_v[2])/cZ
                  top_pos = top_v[1] #Gets Y pos from vector
                  # Rangemap the result to IRR space
                  irrTop_min = c4d.utils.RangeMap(top_pos, 0, 1, 0, rd_h, True)
                  irrTop_max = 0
                  # If its over halfway - reverse it
                  if irrTop_min >= (rd_h/2) :
                      irrTop_max = c4d.utils.RangeMap(irrTop_min, rd_h, rd_h/2, 0, rd_h/2,True)
                      rd[c4d.RDATA_RENDERREGION_TOP] = int(irrTop_max)
                      pass
            Thanks again!
            Cerac
              On 09/07/2018 at 07:09, xxxxxxxx wrote:
              Hi Ceracticus,
              Actually, WS already take care of the film offset, so you just have to do something like that.
                  viewX = bd.GetFrame()["cr"]
                  viewY = bd.GetFrame()["cb"]
                  cam = bd.GetSceneCamera(doc)
                  top = doc.GetFirstObject().GetMg().off
                  bot = doc.GetFirstObject().GetNext().GetMg().off
                  left = doc.GetFirstObject().GetNext().GetNext().GetMg().off
                  right = doc.GetFirstObject().GetNext().GetNext().GetNext().GetMg().off
              	# Get pixels counts between top obj and the frame, then scale this pixel count according to the ratio between viewport size and render size.
                  top_p = max(0, bd.WS(top).y - sf["ct"]) * rd_h / viewY
                  bot_p = max(0, sf["cb"] - bd.WS(bot).y) * rd_h / viewY
                  left_p = max(0, bd.WS(left).x - sf["cl"]) * rd_w / viewX
                  right_p = max(0, sf["cr"] - bd.WS(right).x) * rd_w / viewX
                  rd[c4d.RDATA_RENDERREGION_TOP] = int(top_p)
                  rd[c4d.RDATA_RENDERREGION_BOTTOM] = int(bot_p)
                  rd[c4d.RDATA_RENDERREGION_LEFT] = int(left_p)
                  rd[c4d.RDATA_RENDERREGION_RIGHT] = int(right_p)
              On a side topic, please use [ code] [ /code] to insert code in your post, it increases the readability of them.
              If you have any question, please let me know.
              Maxime
                On 11/07/2018 at 01:05, xxxxxxxx wrote:
                Thanks Maxime,
                i got there in the end, my solution was far less elegant than yours though, so thank you for spending the time to look through my code, i can certainly learn lots from your approach.
                Apologies also for my scrappy code - there was parts in there that made no sense whatsoever so kudos for managing to read through that.
                I'll post my solution below for reference but anyone who references this thread should definitely go with Maximes above suggestion.
                def screenCalc(guide, cZ, bd, sf, rd_w, rd_h) :
                  gPos = guide.GetMg().off  # get global position of guide
                  convertPos = bd.WS(gPos)  # convert world to screen space
                  # Perform safe zone maths
                  convertPos[0] = (convertPos[0] - sf["cl"])/(sf["cr"]-sf["cl"])
                  convertPos[1] = (convertPos[1] - sf["ct"])/(sf["cb"]-sf["ct"])
                  convertPos[2] = (cZ - convertPos[2])/cZ
                  gV1 = convertPos[0]  # get x from vector
                  gV2 = convertPos[1]  # get y from vector
                  # Remaps vector values to screenspace values, aswell as inverts
                  g_Xpos = c4d.utils.RangeMap(gV1, 0, 1, 0, rd_w, True)
                  INVg_Xpos = c4d.utils.RangeMap(gV1, 1, 0, 0, rd_w, True)
                  g_Ypos = c4d.utils.RangeMap(gV2, 0, 1, 0, rd_h, True)
                  INVg_Ypos = c4d.utils.RangeMap(gV2, 1, 0, 0, rd_h, True)
                  # Loads final values into a list and returns it
                  pos = [int(g_Xpos), int(INVg_Xpos), int(g_Ypos), int(INVg_Ypos)]
                  return pos
                  # +------- GET DOCUMENT DATA --------#
                  rd = doc.GetActiveRenderData()               # Get Render Setting
                  rd_w = rd[c4d.RDATA_XRES_VIRTUAL]            # Get X resolution
                  rd_h = rd[c4d.RDATA_YRES_VIRTUAL]            # Get Y resolution
                  sf = bd.GetSafeFrame()                       # Get SafeFrame dims
                  # +------- GET CUSTOM DATA --------#
                  bottom = obj[c4d.ID_USERDATA,7]              # --------------
                  left = obj[c4d.ID_USERDATA,8]                # --------------
                  right = obj[c4d.ID_USERDATA,9]               # --------------
                  cZ = cam[c4d.CAMERAOBJECT_TARGETDISTANCE]    # Get z-distance
                  # If tag is activated
                  if switch:
                      # Use function to grab data
                      try:
                          topPos = screenCalc(top, cZ, bd, sf, rd_w, rd_h)
                          bottomPos = screenCalc(bottom, cZ, bd, sf, rd_w, rd_h)
                          leftPos = screenCalc(left, cZ, bd, sf, rd_w, rd_h)
                          rightPos = screenCalc(right, cZ, bd, sf, rd_w, rd_h)
                          # SET RENDER DATA
                          rd[c4d.RDATA_RENDERREGION_TOP] = topPos[2]
                          rd[c4d.RDATA_RENDERREGION_BOTTOM] = bottomPos[3]
                          rd[c4d.RDATA_RENDERREGION_LEFT] = leftPos[0]
                          rd[c4d.RDATA_RENDERREGION_RIGHT] = rightPos[1]
                          doc.SetActiveRenderData(rd)
                      except ZeroDivisionError:
                          pass
                      pass
                Thanks again,
                Cerac
