    Call Command
    4 Posts 0 Posters 1.4k Views
      On 11/08/2018 at 18:22, xxxxxxxx wrote:
      Hi
      I am trying to do the same thing with a button. But instead of creating a hair object I need it to run "render all materials" from the function menu. Is that possible?
      render all materials call command is - c4d.CallCommand(1225)
      Thanks 🙂
        On 13/08/2018 at 05:22, xxxxxxxx wrote:
        Hello Novacon,
        yes, that is possible. See mfersaoui's code sample four posts above, it does exactly what you want.
        For this to work, the code belongs into a Python tag and the button needs to be placed on the tag, NOT the host object.
        Not sure, where you got the command ID from, maybe just a typo, the ID of "Render All Materials" is 12253.
        Here's mfersaoui's code with a few more comments for better understanding:
        # Additional message() function to react to button presses
        def message(id, data) :
            if id == c4d.MSG_DESCRIPTION_COMMAND:
                id2 = data['id'][0].id
                if id2 == c4d.ID_USERDATA:
                    userDataId = data['id'][1].id
                    if userDataId == 1: # here you need to change the ID to the one of your button
                        # here you can do almost anything in reaction to the button press
                        #print "My User Data Tag Button"
                        c4d.CallCommand(12253) # Render All Materials
        # main() function of the Python tag can still be used as normal.
        # For simplicity of this example it's left empty.
            pass
          On 13/08/2018 at 07:48, xxxxxxxx wrote:
          Hi Andreas
          Thanks a lot that worked 🙂
          Is there anyway of getting it to work on the user data of a Null object?
            On 23/08/2018 at 08:11, xxxxxxxx wrote:
            I'm terribly sorry, I somehow lost your follow up question.
            It's not directly possible (MSG_DESCRIPTION_COMMAND is not forwarded from objects to tags), but there's a workaround described in the Listening for Checkbox Clicks in User Data thread.
