    Detect FPS changed
    2 Posts 0 Posters 892 Views
      On 27/06/2018 at 05:03, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Probably it should be done throught a scene hook but I'm not sure what kind of check should I make to detect if the hook is sent by  a FPS change on the scene.
      Any idea on this?
      Thank you in advance.
        On 29/06/2018 at 05:31, xxxxxxxx wrote:
        Hi Motiva,
        Actually, you can catch a change in a scene by catching EVMSG_CHANGE, which is triggered by any change in the scene.
        To catch such a message you have two options, first to implement a MessageData plugin or either a GeDialog where both of these class have a CoreMessage function where you can listen for such EVMSG_CHANGE .
        Then after is up to you to read the current FPS value for the current value, check if it's different and then do the change/send a message to a particular object.
        If you have any questions, feel free to ask 🙂
        Maxime
