    DrawObject()
    7 Posts 0 Posters 1.8k Views
      On 18/06/2018 at 04:11, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi folks,
      I'm trying to draw a null object inside an ObjectData's Draw() method. I set the nulls position, but when it draws, the position is ignored and instead draws at world centre.
      // There's a few class-level variables here
      // Null_Object is a class level BaseObject::Alloc(Onull)
      DRAWRESULT Demo_Object::Draw(BaseObject *op,DRAWPASS drawpass,BaseDraw *bd,BaseDrawHelp *bh)
      	if(drawpass == DRAWPASS_OBJECT)
      		Draw_Matrix = bh->GetMg();
      		bd->SetMatrix_Matrix(nullptr,Draw_Matrix);
      		Null_Object->SetAbsPos(Vector(0.0,100.0,-250.0));
      		Null_Object->Message(MSG_UPDATE);
      		Draw_Result = bd->DrawObject(bh,Null_Object,DRAWOBJECT_USE_OBJECT_COLOR,drawpass,nullptr,colour_vec);
      		if(Draw_Result == DRAWRESULT_OK){GePrint("Point drawn..");} // prints
      	return SUPER::Draw(op,drawpass,bd,bh);
      I've stripped it to cut to the chase. What am I missing here?
      WP.
        On 19/06/2018 at 02:08, xxxxxxxx wrote:
        BaseDraw::DrawObject() doesn't use the passed object transform. The matrix for the BaseDraw has to be set prior to perform any drawing operation.
        See BaseView / BaseDraw Manual in the C++ docs: Matrix and Objects.
          On 21/06/2018 at 03:53, xxxxxxxx wrote:
          Hi Yannick,
          thanks for your reply. For objects I have in memory (not attached to a document), does this mean I have to construct the matrix myself? I can't use GetMg()?
          WP.
            On 21/06/2018 at 07:03, xxxxxxxx wrote:
            Yes, if the object is not attached to a document then you can't rely on GetMg().
            You can use MatrixMove() to obtain a transformation matrix from a position/translation vector.
              On 22/06/2018 at 03:28, xxxxxxxx wrote:
              Hi Yannick,
              thanks for MatrixMove(), didn't realise that was there!
              I'd been trying to set the matrix with other object matrices but nothing would change it. I shortened it to using the below:
              		bd->SetMatrix_Matrix(nullptr,MatrixMove(Vector(0.0,100.0,-250.0)));
              			GePrint("Null drawn.."); // prints
              but the object is still not drawn where I'd expect. In my initial post I said it was drawing it to world centre, but I've now realised it's drawn to my object's 0,0,0 position. So if I drag my object around the null follows it, does that indicate anything?
              WP.
                On 25/06/2018 at 10:37, xxxxxxxx wrote:
                The behavior you describe makes sense, in DRAWPASS_OBJECT the BaseDraw drawings are done in the object's space.
                Instead of calling bd->SetMatrix_Matrix() try bh->SetMg().
                  On 26/06/2018 at 03:47, xxxxxxxx wrote:
                  Ah, you beaut! Thanks Yannick, that was it. Needed bh->SetMg()!
                  Thanks for you help 👍
                  WP.
