    Generated normals are ignored by C4D
    3 Posts 0 Posters 1.1k Views
      On 23/05/2018 at 08:53, xxxxxxxx wrote:
      Cinema 4D Version:   R19.053
      I generate normals in a NormalTag from C++, but the normals seem to be ignored by C4D in the
      viewport from a shading perspective but also when using the "Vertex Normals" display option in
      the Viewport settings.
      When I export the object as an .OBJ and import it again, the normals are taken into account by
      C4D as expected. I can not spot a difference, however, between the object or its NormalTag that
      I generate and the one that is imported from the .OBJ.
      Here is a link to the C4D scene file with the object:
      https://cloud.niklasrosenstein.com/s/HJ4ZE7BHywYKd9e
      And for clarification:
      Right -- model with normals generated in C++
      Left -- model with normals after importing what is exported from the Right model as .OBJ
      I would expect them to be the same, but the normals of the original model on the Right seem
      to be ignored.
      Thanks in advance,
      Niklas
        On 24/05/2018 at 07:30, xxxxxxxx wrote:
        Hi Niklas,
        could it be you are lacking the phong tag?
        Unfortunately it is not explicitly mentioned in the documentation (we'll fix that), only in the code snippet: NormalTag manual.
          On 24/05/2018 at 17:07, xxxxxxxx wrote:
          That is the culprit, thank you Andreas.
          I keep forgetting that these manuals exist. I think the NormalTag class documentation should link
          to the manual page. 🙂
