    Need to create folder
    4 Posts 0 Posters 1.2k Views
      On 04/05/2018 at 03:42, xxxxxxxx wrote:
      Cinema 4D Version:   R19
      My requirement is to create a folder and store some images there. So Is there any SDK API (c++) to create and access the folder. If there is no API, then please tell me the way to create and access the folder. I have created a command plugin where I need to create a folder.
        On 04/05/2018 at 03:48, xxxxxxxx wrote:
        Have a look in the documentation at GeFile.
        There is a GeFCreateDir function available, amongst others.
        Depending your need you might want to use BrowseFiles to browse the files inside the folder.
        Finally, have a look at the BaseFile, or HyperFile (depending your need).
          On 04/05/2018 at 07:32, xxxxxxxx wrote:
          Maybe you also want to check out the manuals on Files.
            On 04/05/2018 at 07:45, xxxxxxxx wrote:
            Thanks every one.
