    GetDDescription and multiple column elements
    6 Posts 0 Posters 1.4k Views
      On 20/04/2018 at 01:08, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Platform:    Mac  ;
      Greetings to all.
      I'm trying to build a plugin UI via GetDDescription(). Everything is working fine, except I've encountered an issue where I need to "stretch" a single element horizontally so it takes up more than one column in a multi-column group.
      In a *.res file, I'd just use STATICTEXT { JOINENDSCALE; } to achieve what I want.
      However, I can't seem to find an equivalent for this in the C++ API. There's DESC_NEWLINE, but this doesn't seem to do the same thing as JOINENDSCALE. It will take up a column, but then the widget before it won't stretch out horizontally.
      How can I achieve the same effect as JOINENDSCALE in C++?
      -CMPX
        On 20/04/2018 at 06:59, xxxxxxxx wrote:
        did you try to add a static text desc in C++?
          On 20/04/2018 at 08:57, xxxxxxxx wrote:
          Yeah, it just treats it like an empty space and the widget to the left remains unchanged.
          -CMPX
            On 20/04/2018 at 09:14, xxxxxxxx wrote:
            not sure if this will work or not...
            #define STATIC_TEXT_JOINT_END_SCALE 2403
            and in your BaseContainer of the static text desc:
            bc.SetBool(STATIC_TEXT_JOINT_END_SCALE , 1);
              On 20/04/2018 at 21:08, xxxxxxxx wrote:
              Hey, that works great. Dunno why this isn't in the SDK, but it does exactly what JOINENDSCALE does in the *.res files.
              Thanks!
              -CMPX
                On 23/04/2018 at 02:03, xxxxxxxx wrote:
                Hi CMPX and Mohamed,
                I confirm the use of 2403 is the way to go, and produce the exact same thing as JOINENDSCALE does in the res file.
                I will check why this ID is not exposed, and if there are no relevant stopper, this ID will be added to the documentation.
                Maxime
