    CurrentStateToObject
    3 Posts 0 Posters 542 Views
      On 10/04/2003 at 11:58, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:    Mac  ;
      Am I the only one in the forum (and Samir that is being very helpful 😉 ?
      Well, I need to know a few things:
      How can I get a temporaty object that results of a CurrentStateToObject command?
      If I don't insert the object in the document, will I have to throw it away at the end?
      How can I access the point data of that temporay object? (I will probably be able to find this out by myself but now the first two questions 😉
      Thank you very much in advance.
      Rui Batista
      p.s. COFFEE, don't forget
        On 11/04/2003 at 12:20, xxxxxxxx wrote:
        All SendModellingCommand() operations in C.O.F.F.E.E. result in a new object in the scene or changes to the existing objects. There's no way to get just the resulting object back as in C++.
        Did you find out how to access the point data by yourself?
          On 11/04/2003 at 17:09, xxxxxxxx wrote:
          Ok, in that case, how do I create a copy of one object, apply a CurrentStateToObject to it and get the point data? It's not very obvious from the documentation.
          I will delete the created object, afterwards 😉
          Rui Batista
