    Issue with Target Expression tag
    3 Posts 0 Posters 735 Views
      On 20/03/2018 at 10:48, xxxxxxxx wrote:
      Cinema 4D Version:   R19
      Platform:    Mac  ;
      In Target Expression tag not able to enable camera dependent option. In below code, I m creating a Target Expression tag for a camera.
      TextureTag* Tag = static_cast<TextureTag*>(TestCamera->MakeTag(Ttargetexpression));
      if (!Tag)
      return false;
      Tag->SetParameter(TARGETEXPRESSIONTAG_LINK, TargetObj, DESCFLAGS_SET_0);
      Tag->SetName("SetTarget");
        On 21/03/2018 at 09:55, xxxxxxxx wrote:
        As already mentioned in another thread of yours, you really shouldn't cast a Target expression tag into a Texture tag, rather treat it as a BaseTag.
        The camera dependent option is part of the priority. PriorityData a custom data type (CUSTOMGUI_PRIORITY_DATA). So in order to modify this parameter the code looks for example like so:
        	GeData d;
        	targetTag->GetParameter(EXPRESSION_PRIORITY, d, DESCFLAGS_GET_0);
        	PriorityData* prio = static_cast<PriorityData*>(d.GetCustomDataType(CUSTOMGUI_PRIORITY_DATA));
        	prio->SetPriorityValue(PRIORITYVALUE_CAMERADEPENDENT, true);
        	targetTag->SetParameter(EXPRESSION_PRIORITY, d, DESCFLAGS_SET_0);
          On 22/03/2018 at 02:50, xxxxxxxx wrote:
          Thank you so much.
