    Getting data from the current view
    SDK Help
    0
    11
    1.0k
    • H
      On 07/04/2003 at 10:25, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:    Mac  ;
      How do I get access to the data of each editor view?
      I'm particularly interested in the data the we can set with the "Configure..." command. Stuff like the display mode, the image that is on the background, etc.
      Can I access each view independently or do I only get data (and be able to set it) about the current view?
      Please, tell me how to get and set that information from COFFEE.
      Thank you very much in advance.
      Rui Batista
      p.s. Update the COFFEE documentation 😉
      • H
        On 08/04/2003 at 10:03, xxxxxxxx wrote:
        Well, I assume there is no way to get the data I need. Someone correct me if I'm wrong, please 😉
        Rui Batista
        • H
          On 08/04/2003 at 10:47, xxxxxxxx wrote:
          afaik, no.
          • H
            On 08/04/2003 at 11:12, xxxxxxxx wrote:
            Darn!! 😞
            Thank you Samir.
            Rui Batista
            • H
              On 08/04/2003 at 18:59, xxxxxxxx wrote:
              Well, I'm not convinced!!! 😉
              I'm not doubting you, Samir. I'm just too upset if this is really not accessible. Come on!! Can someone from Maxon confirm that it is really not possible to access the editor view data?
              Rui Batista
              • H
                On 09/04/2003 at 02:58, xxxxxxxx wrote:
                It isn´t. There isn´t even absolute access with C++, so how should there be in COFFEE? But if you want to waste time waiting for somebody else to confirm, do so. It´s not my time 😉
                • H
                  On 09/04/2003 at 04:07, xxxxxxxx wrote:
                  Double darn!! Ok, thanks again, Samir.
                  But if there is a class named BaseView that deals with editor views its simply stupid that we don't have access to that data.
                  For instance, in the SDK we have:
                  void GetParameter(Vector* offset, Vector* scale, Vector* scale_z)
                  Retrieves the parameters for the current projection.
                  and
                  LONG GetProjection(void)
                  Returns the projection used by the view.
                  We ca have access to that. Why not to the configuration?
                  I see that the SDK still has to evolve a lot. For C++ and COFFEE.
                  Rui Batista
                  • H
                    On 09/04/2003 at 04:13, xxxxxxxx wrote:
                    In C++ you can set the image etc but not in COFFEE.
                    • H
                      On 09/04/2003 at 04:17, xxxxxxxx wrote:
                      ARRRGGGHHH!!! When will COFFEE be updated?!?!? This question is not for you, Samir 😉
                      Rui Batista
                      • H
                        On 11/04/2003 at 12:22, xxxxxxxx wrote:
                        This is not possible in C.O.F.F.E.E.
                        • H
                          On 11/04/2003 at 16:49, xxxxxxxx wrote:
                          Will COFFEE ever evolve? In my lifetime? 😉
                          Rui Batista
