    RIGID_BODY_CLEAR_INITIAL_STATE
    7 Posts 0 Posters 1.0k Views
      On 08/03/2018 at 21:46, xxxxxxxx wrote:
      Hello all,
      I try python CallButton, but it dosen't work.
      c4d.CallButton(tag, c4d.RIGID_BODY_CLEAR_INITIAL_STATE)
      I can't find "RIGID_BODY_CLEAR_INITIAL_STATE" CallCommand number.
      Do you know that?
        On 09/03/2018 at 03:07, xxxxxxxx wrote:
        Hello Nob,
        Actually CallButton is the right way to go. And it should work (and it's working fine here).
        So may I ask you a few more information about where you execute it, maybe tag is not define or is not the right one?
        CallCommand is more used to use tool like reversenormal or execute a cut for example, so you can't use it in this context.
        Moreover just for your personal knowledge all constant you get (from the Console Log or either by drag and drop a parameter on the console or the script manager) are actually Integer.
        So if in the console you write c4d.RIGID_BODY_CLEAR_INITIAL_STATE (always add c4d, sicne constants are stored in the c4d module) it will print you the actual id of this action/button/parameter.
        Please do not hesitate if you feel lost, or you don't understand something.
        Maxime
          On 09/03/2018 at 20:11, xxxxxxxx wrote:
          Thanks for the reply.
          I am making ToolData Pugin. It is to paint the object with a mouse. Paint uses dynamics.
          tag [c4d.RIGID_BODY_INITIAL_LINEAR_VELOCITY] is used in def MouseInput.
          Can c4d.RIGID_BODY_INITIAL_LINEAR_VELOCITY be used with ToolData? Or can you use def MouseInput?
            On 12/03/2018 at 02:53, xxxxxxxx wrote:
            Hi Nob,
            I'm not sure your last question is related to the first one.
            Does your initial question is completely resolved?
            If yes, please feel free to open a new thread for your last question.
            Owever make sure to share as most informations as you can, it will really help us to help you 🙂
            Maxime
              On 13/03/2018 at 07:43, xxxxxxxx wrote:
              Sorry, it was a different question.
              Is CallButton possible in the ToolData plugin class?
              def MouseInput(self, doc, data, bd, win, msg) :
                On 14/03/2018 at 03:56, xxxxxxxx wrote:
                Hi Nob,
                I would like to ask you at least a day in order to gather some more informations.
                Thanks 🙂
                  On 15/03/2018 at 03:15, xxxxxxxx wrote:
                  Hi Nob,
                  after some discussions it's completely fine to use CallButton from MouseInput function of a ToolData.
                  So if it's not working as you expected or you encounter any issues please feel free to ask.
                  Maxime
