    Creating Cube Using Python
    4 Posts 0 Posters 1.0k Views
      On 07/03/2018 at 17:37, xxxxxxxx wrote:
      I'm trying to create a simple gui to create a cube. Currently, it looks like this
      https://www.dropbox.com/s/upcc1wykyall32a/c4d057_createCube02.jpg?dl=0
      Based on the image above, my current problem is adding the labels in the side. And adding a cm to the number boxes.
      Is there a way I can do that?
      I tried using the .AddStaticText but it breaks the code and removes all the input boxes in the GUI.
      Here is the working script:
      from c4d import gui
      nameBox = 1001
      sliderBox = 1002
      numberBox = 1003
      Create = 1004
      class CreateCube(gui.GeDialog) :
          def CreateLayout(self) :
              self.SetTitle('Create Cube')
              self.AddEditText(nameBox, c4d.BFH_SCALEFIT)
              self.AddEditSlider(sliderBox, c4d.BFH_SCALEFIT)
              self.AddEditNumber(numberBox, c4d.BFH_SCALEFIT)
              self.AddButton( Create, c4d.BFH_SCALEFIT , name='Create Cube')
              self.GroupEnd()
          def Command (self, id, msg) :
              if id==Create:
                  cube  = c4d.BaseObject(c4d.Ocube)
                  text_value = self.GetString(nameBox)
                  slider_value = self.GetInt32(sliderBox)
                  number_value = self.GetInt32(numberBox)
                  cube[c4d.ID_BASELIST_NAME]=text_value
                  cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_X]=slider_value
                  cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_Y]=slider_value
                  cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_Z]=slider_value
                  cube[c4d.PRIM_CUBE_SUBX]=number_value
                  cube[c4d.PRIM_CUBE_SUBY]=number_value
                  cube[c4d.PRIM_CUBE_SUBZ]=number_value
                  self.cube = cube
                  self.Close()
          dialog = CreateCube()
          dialog.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=200,defaulth=200)
          cube = dialog.cube
          doc.InsertObject(cube)
      Thank you for your time.
        On 08/03/2018 at 02:46, xxxxxxxx wrote:
        Hey Ben,
        You can use AddStaticText like this below, also and example of setting floats as types:
        from c4d import gui
        nameBox       = 1001
        sliderBox     = 1002
        numberBox     = 1003
        Create        = 1004
        name_TextID   = 1005
        slider_TextID = 1006
        number_TextID = 1007
                self.AddStaticText(name_TextID  , c4d.BFH_LEFT     ,initw=200, name="Input cube name : ", borderstyle=c4d.BORDER_NONE)
                self.AddEditText  (nameBox      , c4d.BFH_SCALEFIT)
                self.AddStaticText(slider_TextID, c4d.BFH_LEFT     ,initw=200, name="Cube size: ", borderstyle=c4d.BORDER_NONE)
                self.AddEditSlider(sliderBox    , c4d.BFH_SCALEFIT)
                self.AddStaticText(number_TextID, c4d.BFH_LEFT     ,initw=200, name="Cube subdivisions : ", borderstyle=c4d.BORDER_NONE)
                self.AddEditNumber(numberBox    , c4d.BFH_SCALEFIT)
                self.AddButton    (Create       , c4d.BFH_SCALEFIT ,name='Create Cube')
                self.cube = None # This is so we can check it's existance later on so we don't get an error if we close the window without pressing the create button
                self.GroupEnd()
            def InitValues(self) :
                self.SetString(nameBox,'Enter cube name here')
                self.SetFloat(sliderBox,200,format=c4d.FORMAT_METER)#Or you can use .SetMeter() instead of SetFloat
                self.SetInt32(numberBox,1,min=1)
                if id==Create:
                    self.cube = cube # Changing self.cube from None to the cube we just made
                    self.Close()
            if not dialog.cube: return
            cube = dialog.cube
        Adam
          On 08/03/2018 at 08:55, xxxxxxxx wrote:
          welcome to the Plugin Café forums 🙂 (or are you just using another account and are actually btbentraje?)
          Anyway, Adam already answered your questions.
          In CreateLayout() you are calling GroupEnd() without actually having begun a group. That's redundant and might (at least) lead to confusing situations, when extending the code later on.
          I'd rather handle both the slider and the edit field completely as float (also using GetFloat() on read) and then round later on. Also Adam accidentally just set the unit for the slider, you will want that for the numberBox as well.
          Links to the docs: SetFloat(), SetMeter()
          And although in our C++ documentation, the GeDialog manual might be an interesting read, too.
            On 08/03/2018 at 20:01, xxxxxxxx wrote:
            Thanks Adam and Andreas for the response!
            It works as expected.
            Yes, I am also btbentraje. At that time I forgot this account. Hahaha You can delete the btbentraje account if you want.
            Thank you again.
