    Get value from object that is in a tab.
    3 Posts 0 Posters 783 Views
      On 20/02/2018 at 14:18, xxxxxxxx wrote:
      Hi guys,
      Maybe a really simple questions. Normally when I need to excess a value from an object I copy the text field inside the console and do a print command.
      Now I need to excess the range start and range end value from the Redshift Proxy object. (see image below) But you can't drag them into the console because there in a tab. (proxy/animation)
      You can also access them from the Xpresso Editor.
      There must be a way right?
      Hope someone has an answer:)
        On 21/02/2018 at 02:18, xxxxxxxx wrote:
        Hi JW Zegelaar,
        Most of the time, when you need to access individual parameter from a CustomGui you can right click on this parameter (File in your case) => User Interface => Show Subcontainer.
        Then you will be able to drag/drop in the console each parameter.
        Which will give us
        op[c4d.REDSHIFT_PROXY_FILE,c4d.REDSHIFT_FILE_ANIMATION_RANGE_START] = c4d.BaseTime(0.5)
        op[c4d.REDSHIFT_PROXY_FILE,c4d.REDSHIFT_FILE_ANIMATION_RANGE_END] = c4d.BaseTime(1)
          On 22/02/2018 at 13:26, xxxxxxxx wrote:
          Perfect! Is this exactly what I need!
          Thanks you so much!😪
