    Best practice for BaseContainer Types
    2 Posts 0 Posters 494 Views
      On 16/02/2018 at 01:11, xxxxxxxx wrote:
      Hi Everyone,
      Im currently writing a plugin that stores and retrieves takes data.
      Im planning to store 5 separate lists of strings in a sub-basecontainer (to keep the data with the file)
      (following along from this post -  https://developers.maxon.net/forum/topic/8019/10416_saving-custom-attributes-with-a-scene-file)
      So, as per this:
      subC = c4d.BaseContainer()
      subC.SetString(NAME_IDS _, NAME_LIST _)
      __ What do i need to set the the subC type to, so i can store lists?
      And if i want to store 5 separate lists of strings, is there any conflict i need to be aware of? _
      "Once you've set a container value using one type you must neither try to access it using another type, nor overwrite it with a value of another type! Using the wrong access will not crash, but it is illegal."
      _ I am fully aware of the above from the documentation, hence asking for advice on best practice.
      Any and all information would be much appreciated!
      Cerac __
        On 16/02/2018 at 03:45, xxxxxxxx wrote:
        You will need to provide your own list implementation.
        I do this by creating a subcontainer, storing the number of entries at index 0, then storing the different entries at following indeces (or in a separate subcontainer)
        Something like
        BaseContainer bcList;
        bcList.SetInt32(0, count);
        BaseContainer bcData;
        for (Int32 i = 0; i < count; ++i)
          bcData.SetString(name_list[i]);
        bcList.SetContainer(1, bcData);
