    object identity (id) changes
    2 Posts 0 Posters 593 Views
      On 10/02/2018 at 04:33, xxxxxxxx wrote:
      according to the Python manual:
      Return the ``identity'' of an object. This is an integer (or long integer) which is guaranteed to be unique and constant for this object during its lifetime. Two objects with non-overlapping lifetimes may have the same id() value. (Implementation note: this is the address of the object.)
      When I query the id of an object, I get a variety of numbers, as well as a variety of memory allocations, that loop regularly.
      https://www.dropbox.com/s/ndbbqh0hra8l7hf/id varying 01A.c4d?dl=0
      my intention is to generate a unique name for an object so that it's consistent for the lifetime of that object
      Thanassis
        On 10/02/2018 at 05:09, xxxxxxxx wrote:
        as usual, I searched a bit more and found the solution.
        I followed another thread and found GetGUID()
        Here's the result. Each cube has a unique GUID
        https://www.dropbox.com/s/hlzm08usn2awbm1/GetGUID%2002A.c4d?dl=0
