    Draw highlight
    6 Posts 0 Posters 1.4k Views
      On 12/01/2018 at 19:46, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      Hi folks,
      is it possible to turn off the highlighting 'feature' when I draw a LineObject inside my ObjectData plugin's Draw() function? Currently if my object is selected the lines are drawn white.
      WP.
        On 15/01/2018 at 05:33, xxxxxxxx wrote:
        Hi WickedP, thanks for writing us.
        With reference to your request, could you please better explain your final intent? Could you also confirm that you need to draw a line using the BaseDraw::DrawLine() in ObjectData::Draw() rather than dealing with LineObject which has completely different purposes?
        Best, Riccardo
          On 15/01/2018 at 23:11, xxxxxxxx wrote:
          Hi knickknack,
          I'm wanting to draw a spline in an ObjectData's Draw() function. So I'm getting the LineObject from a SplineObject, and using DrawObject() to draw the LineObject. Psuedo code:
          // set spline points
          LineObject *line = Spline->GetLineObject(nullptr,0.0,nullptr)
          bd->DrawObject(bh,line,DRAW_FLAGS,drawpass,nullptr,colour);
          // etc..
          The spline/line is drawn fine. But it's highlighted - I want the colour drawn to the colour I set regardless of whether the object is selected or not.
          WP.
            On 16/01/2018 at 02:26, xxxxxxxx wrote:
            Hi WickedP, thankls for following up.
            To avoid having your item "highlighted" simply draw it in the DRAWPASS_OBJECT rather than in the DRAWPASS_HIGHLIGHTS being sure that the pen color is set to BaseDraw::GetObjectColor() instead of BaseDraw::GetHighlightPassColor().
            Best, Riccardo
              On 17/01/2018 at 01:37, xxxxxxxx wrote:
              Hi knickknack,
              that's the thing, I'm drawing it in DRAWPASS_OBJECT and setting the pen colour isn't having any effect. It just draws the line white unless I deselect my object. This is a stripped down version of my function (psuedo to keep it minimal) :
              DRAWRESULT My_Object::Draw(BaseObject *op,DRAWPASS drawpass,BaseDraw *bd,BaseDrawHelp *bh)
                  if(drawpass == DRAWPASS_OBJECT)
                      // set spline points/tangents here
                      // (spline is a class level variable)
                      LineObject *line = My_Spline->GetLineObject(nullptr,0.0,nullptr);
                      // this line doesn't change anything
                      bd->SetPen(bd->GetObjectColor(bh,My_Spline,FALSE),NULL);
                      Vector col = Vector(1.0,0.0,0.0);
                      Draw_Result = bd->DrawObject(bh,line,DRAWOBJECT_EDITMODE|DRAWOBJECT_FORCEPOINTS|DRAWOBJECT_USE_CUSTOM_COLOR,drawpass,nullptr,col);
                      LineObject::Free(line);
                      if(Draw_Result == DRAWRESULT_OK)
                          GePrint("Drawn.");
                  return SUPER::Draw(op,drawpass,bd,bh);
              Just in addition to the highlighting issue, the DRAWOBJECT_FORCEPOINTS flag doesn't seem to do anything here. Can I draw points from the line object as well?
              WP.
              Edit: fixed typo.
                On 16/03/2018 at 01:00, xxxxxxxx wrote:
                Hi folks,
                I know this is a couple of months old, but I'm having a really frustrating time with this. I've tried returning the spline in GVO instead but it does the same thing. When I add a cube and set the colour with ObjectColorProperties the cube is coloured fine. Why are splines different?
                Can I colour the spline so that it's not affected by the draw highlight? There must be a way. How is the normal spline object drawn (with the white-to-blue curve colour and points)?
                WP.
