    Button in Object Generator plugin
    4 Posts 0 Posters 628 Views
      On 08/01/2018 at 07:36, xxxxxxxx wrote:
      I have an Object Generator plugin that has an only one button.
      I want to perform some operations when pressing it.
      For example, create a sphere and insert it under Object Generator plugin...
      Here is how my code looks like, but it's not working...
      from c4d import plugins, utils
      import os
      TESTPLUGIN_ID = 1040447
      TESTPLUGIN_VALUE = 1000
      class Testplugin(c4d.plugins.ObjectData) :
          def Message(self, node, type, data) :
              if type == c4d.MSG_DESCRIPTION_COMMAND:
              if data["id"][0].id == TESTPLUGIN_VALUE:
                      sphere = c4d.BaseObject(c4d.Osphere)
                      sphere.InsertUnder(node)
          fn = os.path.join(dir, "res", "icon.tif")
          bmp.InitWith(fn)
          result = plugins.RegisterObjectPlugin(
              id = TESTPLUGIN_ID,
              str = "Test Plugin",
              g = Testplugin,
              description =
              "Otestplugin",
              info = c4d.OBJECT_GENERATOR,
              icon = bmp)
        On 08/01/2018 at 10:12, xxxxxxxx wrote:
        Figured it out...
          1. import c4d
          2. from c4d import plugins, utils
          3. import os
          4.
          5. TESTPLUGIN_ID = 1040447
          6. TESTPLUGIN_VALUE = 1000
          7.
          8. class Testplugin(c4d.plugins.ObjectData) :
          9.
          10.     def Message(self, node, type, data) :
          11.         if type == c4d.MSG_DESCRIPTION_COMMAND:
          12.             if data["id"][0].id == TESTPLUGIN_VALUE:
          13.                 sphere = c4d.BaseObject(c4d.Osphere)
          14.                 sphere.InsertUnder(node)
          15.         return True
          16.
          17. if __name__ == "__main__":
          18.     bmp = c4d.bitmaps.BaseBitmap()
          19.     dir, file = os.path.split(__file__)
          20.     fn = os.path.join(dir, "res", "icon.tif")
          21.     bmp.InitWith(fn)
          22.     result = plugins.RegisterObjectPlugin(
          23.         id = TESTPLUGIN_ID,
          24.         str = "Test Plugin",
          25.         g = Testplugin,
          26.         description =
          27.         "Otestplugin",
          28.         info = c4d.OBJECT_GENERATOR,
          29.         icon = bmp)
          On 08/01/2018 at 10:13, xxxxxxxx wrote:
          I had to convert tabs into spaces
            On 09/01/2018 at 02:51, xxxxxxxx wrote:
            Hi Merk,
            Python pays a lot of attention to indentation and is never suggested to mix up spaces and tabs. Beware for the next time 😉
            Best, Riccardo
