    Remapping textures in non-diffuse channels
    2 Posts 0 Posters 431 Views
      On 25/01/2018 at 04:03, xxxxxxxx wrote:
      Hi everyone,
      how would one do this in between version R16 and R17 since the method "GetAllReflectionShaders()" is only available from R17.032 on?
      For versions prior R16 you can of course use [MATERIAL_REFLECTION_SHADER] but this has gone in R16 due to reflectance. So is one lost in between R16 and R17.032 when it comes to retrieving shaders loaded in a shader slot in reflectance channel?
        On 26/01/2018 at 02:55, xxxxxxxx wrote:
        I'm afraid back in R16 no proper Python API existed to access reflectance layer settings.
        So the only way to get the shaders would be somewhat of a hack. You could try to get a shader that is used in the material and then run over the whole shader tree. But this would obviously fail if there is no other shader outside the reflectance channel.
