    Drag and drop to UserArea
    2 Posts 0 Posters 491 Views
      On 25/12/2017 at 01:22, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      How can I get an animatable parameter by drag and drop?
      The Object Manager object was created by adding LinkBoxGUI with AddCustomGui.
      Is there a drag-and-drop correspondence GUI for the parameter?
      Since I was not able to make LinkBox remodeling because it was difficult, I wanted to create it using user area drag and drop, but I saw the sample file of SDK manual and AsyncTest and made it for the same, but I understood how to receive the message did not.
      #pragma once
      #include "c4d.h"
      #include "c4d_commanddata.h"
      #include "c4d_gui.h"
      #define IDS_UserAreaTest 1000001
      Bool RegisterUserAreaTest(void);
      Bool PluginStart(void)
           if (!RegisterUserAreaTest())
                return false;
           return true;
      void PluginEnd(void)
      Bool PluginMessage(Int32 id, void* data)
           switch (id)
                case C4DPL_INIT_SYS:
                     return true;
                case C4DMSG_PRIORITY:
                     return true;
                case C4DPL_BUILDMENU:
                     break;
                case C4DPL_COMMANDLINEARGS:
                     break;
                case C4DPL_EDITIMAGE:
                     return false;
           return false;
      class UserAreaLinkBox : public GeUserArea
           virtual Bool GetMinSize(Int32& w, Int32& h);
           virtual void DrawMsg(Int32 x1, Int32 y1, Int32 x2, Int32 y2, const BaseContainer& msg);
      Bool UserAreaLinkBox::GetMinSize(Int32& w, Int32& h)
           w = 100;
           h = 20;
           return true;
      void UserAreaLinkBox::DrawMsg(Int32 x1, Int32 y1, Int32 x2, Int32 y2, const BaseContainer& msg)
           this->OffScreenOn();
           this->DrawSetPen(Vector(110, 110, 0));
           this->DrawRectangle(x1 + 2, y1 + 2, x2 - 2, y2 - 2);
      class UserAreaTestDialog : public GeDialog
           virtual Bool CreateLayout();
           virtual Int32 Message( const BaseContainer& msg, BaseContainer& result );
           virtual Bool CoreMessage( Int32 id, const BaseContainer &msg; );
           void Update();
           UserAreaLinkBox ua;
      Bool UserAreaTestDialog::CreateLayout()
           SetTitle( "UserAreaTest" );
           Update();
           return true;
      Int32 UserAreaTestDialog::Message( const BaseContainer& msg, BaseContainer& result )
           switch (msg.GetId())
                case BFM_DRAGRECEIVE:
                     if (msg.GetInt32(BFM_DRAG_LOST))
                          GePrint("BFM_DRAG_LOST");
                     if (msg.GetInt32(BFM_DRAG_FINISHED))
                          GePrint("BFM_DRAG_FINISHED");
                     if (CheckDropArea(200, msg, true, true))
                          GePrint("CheckDropArea");
                     break;
                default:
                     break;
           return GeDialog::Message( msg, result );
      void UserAreaTestDialog::Update()
           LayoutFlushGroup(100);
           FreeChildren(100);
           GroupBegin(100, BFH_SCALEFIT, 1, 1, "", BFV_BORDERGROUP_FOLD_OPEN, 0);
                C4DGadget* c4dgadget = AddUserArea(200, BFH_SCALEFIT, 100, 20);
                if (c4dgadget)
                     AttachUserArea(ua, 200);
           GroupEnd();
           LayoutChanged(100);
      Bool UserAreaTestDialog::CoreMessage( Int32 id, const BaseContainer &msg; )
           switch( id )
                case EVMSG_CHANGE:
                     Update();
                     break;
           return GeDialog::CoreMessage( id, msg );
      class UserAreaTest : public CommandData
           INSTANCEOF( UserAreaTest, CommandData )
           virtual Bool Execute( BaseDocument* doc );
           virtual Bool RestoreLayout( void* secret );
           static UserAreaTest* Alloc() { return NewObjClear( UserAreaTest ); }
      private:
           UserAreaTestDialog _dialog;
      Bool UserAreaTest::Execute( BaseDocument* doc )
           if( _dialog.IsOpen() == false )
                _dialog.Open( DLG_TYPE_ASYNC, IDS_UserAreaTest, -1, -1, 400, 400 );
           return true;
      Bool UserAreaTest::RestoreLayout( void* secret )
           return _dialog.RestoreLayout( IDS_UserAreaTest, 0, secret );
      Bool RegisterUserAreaTest( void )
           return RegisterCommandPlugin( IDS_UserAreaTest, String( "UserAreaTest" ), 0, nullptr, String( "UserAreaTest" ), UserAreaTest::Alloc() );
      GePrint ("BFM_DRAG_LOST");
      GePrint ("BFM_DRAG_FINISHED");
      Please tell me how to get to.
      Or please tell me if there is better usage.
        On 26/12/2017 at 00:06, xxxxxxxx wrote:
        I have now seen the fact of shock.
        I accidentally saw this forum with a different personal computer.
        When searching using the keyword of drag, the same question hit a lot.
        I noticed the cause was investigated.
        When this forum is logged in, the search result is greatly reduced.
        Why is this forum constantly watching nearly 100 people. I was concerned that there was only one or two people logging in.
        I will not be able to recover for the time being.
