CSTO and materials
On 19/12/2017 at 06:00, xxxxxxxx wrote:
In my CSTO function I use a new document to copy my object to.
However, when I do so, the materials used are not copied to the new document and thus the result of the CSTO has no material information, displaying a question mark.What can i do in order not to loose the material information.
newDoc = c4d.documents.BaseDocument() newDoc.InsertObject(obj) objList = c4d.utils.SendModelingCommand( command = c4d.MCOMMAND_CURRENTSTATETOOBJECT, list = [obj], mode = c4d.MODELINGCOMMANDMODE_ALL, doc = newDoc, flags = c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE) if objList == False: print "error CSTONewDoc." obj.Remove() -
On 19/12/2017 at 06:05, xxxxxxxx wrote:
On 19/12/2017 at 07:06, xxxxxxxx wrote:
So, I use it to copy my object to a new document and using that document i do a csto.
After that, do I have to copy (how) the resulting object back to my original document?
The code below gives me still the question marks, indicating that the materials were not found.
newDoc = c4d.documents.IsolateObjects(doc, [obj]) objList = c4d.utils.SendModelingCommand( command = c4d.MCOMMAND_CURRENTSTATETOOBJECT, list = [obj], mode = c4d.MODELINGCOMMANDMODE_ALL, doc = newDoc) #flags = c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE) if objList == False: print "error CSTONewDoc." obj.Remove() return objList[0] -
On 20/12/2017 at 05:20, xxxxxxxx wrote:
Hi Pim,
Where are you using the posted code? Inside GetVirtualObjects()? What's obj in it?
If a temporary document is created for CSTO then the command loses track of the materials.
And IsolateObjects() copies the passed object so you don't know the object that has to be used for CSTO.It is recommended to pass a clone of the object to apply CSTO on. So you can pass obj.GetClone().
The document for CSTO can simply be obj's document - obj.GetDocument().
CSTO should keep materials with these changes.Note SendModelingCommand() flags parameter only accepts either MODELINGCOMMANDFLAGS_0 or MODELINGCOMMANDFLAGS_CREATEUNDO.
The settings for a modeling command have to be passed to bc parameter. -
On 20/12/2017 at 05:49, xxxxxxxx wrote:
Hi Yannick,
Yes it is inside GetVirtualObjects() and after GetAndCheckHierarchyClone().
Obj is a null with a smoothing deformer en a polygon object as child's.
The polygon object has a texture tag and a weight tag.I do not fully understand your sentence
"It is recommended to pass a clone of the object to apply CSTO on. So you can pass obj.GetClone().
CSTO should keep materials with these changes."- I do not see a difference when using a clone, but I will try again.
- If I use the current document, obj.GetDocument(), the weight setting in the smoothing deformer is lost.
If I use a new document, the weight setting in the smoothing deformer is ok.
But then the material is lost due the new document.That is why I want to know how to keep the mat information when using csto and e new document.
-Pim
On 21/12/2017 at 03:26, xxxxxxxx wrote:
Hi Pim,
Ok, I believe you use the code posted in the other thread Vertex map is not correctly filled?
You can't get both the weight and material shown as expected.
The vertex map is created on a cache object and is not part of the document, while the material is.So the solution is to add the vertex map to the child's polygon object of your generator, instead of creating it virtually.
Also this way it would give more freedom to define the vertex map, for instance with the Paint Tool.And about passing a clone to CSTO, you're right it's not needed.
On 21/12/2017 at 03:33, xxxxxxxx wrote:
Sorry, I do not fully understand.
I am adding the vertex weight to the polygon object.
Then I copy this weight tag into the Stiffness map field of the Smoothing deformer object.
Both are placed under a Null and that null must be CSTOed.Could you give an example?
- Pim
On 21/12/2017 at 08:43, xxxxxxxx wrote:
Hi Pim,
So the solution is to add the vertex map to the child's polygon object of your generator , instead of creating it virtually.I mean the vertex map should be manually added to the generator's child, not virtually to the child's clone inside GetVirtualObjects().
Then access the vertex map with GetTag() on the child from GetVirtualObjects().
Finally CSTO should be performed with the generator's document, not with a temporary one.This changes the workflow but is there a strong reason to generate the vertex map inside your generator?
On 21/12/2017 at 09:13, xxxxxxxx wrote:
Ok, i see, but yes, the vertex map is generated inside getvirtualobjects().
IT is based on csto's Before.
The generator can hold numerous children.But if this is the only way, then we must think about the workflow.
Thanks, Pim
