Plugin doesn't work if child has tag(tex,dynamics,
On 17/12/2017 at 15:25, xxxxxxxx wrote:
I have a test plugin that simply extrudes all polygons from its child object.
It's working without any problems when the child object has a phong tag or most of the other tags, but seems like certain tags can't be used with it. For example, if I attempt to assign dynamics tag, texture tag, Compositing tag ... it stops working.
I can't see any error messages in the console.Which part of this code should I change in order to bypass this issue?
Thanks.
- def GetVirtualObjects(self, op, hh) :
- #Check child Object
- child = op.GetDown()
- if not child: return None
- #Create clone
- cloneGenerator = op.GetAndCheckHierarchyClone(hh, child, c4d.HIERARCHYCLONEFLAGS_ASPOLY, False)
- dirty = cloneGenerator["dirty"]
- clone = cloneGenerator["clone"]
- children = clone.GetChildren()
- if not dirty:
- return clone
- #Crete Connect Generator
- connect = c4d.BaseObject(1011010)
- connect[c4d.CONNECTOBJECT_WELD] = False
- clone.InsertUnder(connect)
- #Make Editable
- res1 = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
- list = [connect],
- doc = child.GetDocument())[0]
- #Extrude all polygons
- settings = c4d.BaseContainer()
- settings[c4d.MDATA_EXTRUDE_OFFSET] = op[10000]
- res = c4d.utils.SendModelingCommand (command = c4d.ID_MODELING_EXTRUDE_TOOL,
- list = [res1],
- mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION,
- bc = settings,
- #Return Result
- return res1
On 19/12/2017 at 08:17, xxxxxxxx wrote:
I had similar issues running the CURRENTSTATETOOBJECT-command.
If I remember correctly, depending on the tags it returns a null-object with the converted object underneath. So you'll need to check if res1 is a null-object and if so if "res1.GetDown()" returns a polygonal object.Phil
On 19/12/2017 at 09:13, xxxxxxxx wrote:
I confirm the behavior outlined by Phil.
Current State to Object command keeps objects with hierarchical tags and inserts these under a null object that is returned, instead of just a polygon object.
