    Accessing object properties
    4 Posts 0 Posters 737 Views
      On 15/12/2017 at 13:17, xxxxxxxx wrote:
      Hi!
      I'm looking to write a simple script that goes through each frame and saves some data (position and rotation coordinates) from the selected object. However the documentation lists only methods, no properties and I can't figure out how to access the data.
      Dragging in the name of the coordinate field to the Python editor places something like this in the code: [c4d.ID_BASEOBJECT_POSITION,c4d.VECTOR_X], which is a list of 2 integers that don't seem to correlate to the value of the given coordinate.
      Help please, thank you,
      zoliking
        On 17/12/2017 at 11:37, xxxxxxxx wrote:
        So after failing to find a tutorial I decided to find some example scripts and try to get somewhere from there. I managed to find the method doc.GetFirstObject(), which allowed access to the data I need. However I ran into a new problem: the instance it returns seems to contain the information about the object on the frame I start the script on, not the frame that the application is on during the call. Any ideas?
        def goToFrame(frameNumber) :
          fps = doc[c4d.DOCUMENT_FPS]
          time = c4d.BaseTime(frameNumber, fps)
          doc.SetTime(time)
          data = []
          for i in range(0,46) :
              goToFrame(i)
              selectedObject = doc.GetFirstObject()
              pos = selectedObject.GetAbsPos()
              rot = selectedObject.GetAbsRot()
              data.append(pos.x)
              data.append(pos.y)
              data.append(pos.z)
              data.append(rot.y)
              data.append(rot.x)
              data.append(rot.z)
          On 18/12/2017 at 01:58, xxxxxxxx wrote:
          Objects in Cinema 4D store parameters. Such parameters are identified using a DescID object. A DescID object is made of various numbers and these numbers are typically defined using symbols. c4d.ID_BASEOBJECT_POSITION and c4d.VECTOR_X are such symbols. So you can use these symbols to access parameter values using GetParamter() :
          descid = c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, 0, 0), c4d.DescLevel(c4d.VECTOR_X, 0, 0))
          xCoordiante = op.GetParameter(descid, c4d.DESCFLAGS_GET_0)
          But there are shorter ways of writing the same thing using the subscript operator:
          xCoordiante = op[c4d.ID_BASEOBJECT_POSITION,c4d.VECTOR_X]
          In the online documentation you find information on GetParameter() and DescID. You find various Python examples in the Python documentation download[URL-REMOVED] and on GitHub.
          Setting the time of a document will NOT animate the document. To animate the document you explicitly do that. This can be done using ExecutePasses().
          A similar topic was just discussed in this thread: "python plugin for every frame".
          You also find additional information in the C++ documentation on these topics: BaseDocument Manual.
            On 18/12/2017 at 08:33, xxxxxxxx wrote:
            ExecutePasses() worked, thank you for that and all the other great information too! You are a life saver!
