    Bitmap Buttons
    4 Posts 0 Posters 539 Views
      On 02/04/2003 at 13:51, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:      Mac OSX  ;
          I implemeted the source code found in this forum for a BitmapButton. The original res declaration for the button is in the res file ( BITMAPBUTTON PLUGIN_BUTTON {} ). Everything works fine except there is no event generated when the button is clicked on. I am checking using the following:
      case MSG_DESCRIPTION_COMMAND:
                                    DescriptionCommand *dc = ( DescriptionCommand * ) data;
                                    if ( dc->id[0].id == PLUGIN_BUTTON )
                                              GePrint( "Here We Are" ); // ***
      This message is never sent unless I change the res file element to BUTTON instead of BITMAP_BUTTON. I think that I am not setting a seond image for the button may be an issue. The code I found only sets one image:
      case MSG_DESCRIPTION_GETBITMAP:
                                    DescriptionGetBitmap* dgb = static_cast < DescriptionGetBitmap * > ( data );
                                    if ( dgb->id[0] == PLUGIN_BUTTON )
                                              AutoAlloc < BaseBitmap > bm;
                                              bm->Init( GeGetPluginPath() + Filename( "res" ) + Filename( "PLUGIN_BUTTON_UP.tif" ) );
                                              dgb->bmp = bm.Release();
      Where and how should I set the second down image? Is it possible that is why there is not event generated?
      Thanks!
      bt
        On 04/04/2003 at 01:24, xxxxxxxx wrote:
        I would like to know that too :
        Trying to get teh Customdatatype and setting the image with SetImage() (no matter where) or even GetHeight does crash my cinema 4d immediately.
        P.S.: Would be highly appreciated if you could tell me if you find out darf. Thanks
          On 04/04/2003 at 04:58, xxxxxxxx wrote:
          You must set the "BITMAPBUTTON_BUTTON" flag in the settings. In the resource file this means "BITMAPBUTTON PLUGIN_BUTTON {BUTTON; }".
            On 04/04/2003 at 05:05, xxxxxxxx wrote:
            I did BITMAPBUTTON ID {BORDER; BUTTON;}
            But that doesn´t help setting a second image when the button is pressed down. :
            BitmapButtonCustomGui butt = (BitmapButtonCustomGui* )data->GetCustomDataType(id,CUSTOMGUI_BITMAPBUTTON);
            butt->SetImage(bm,TRUE);
            this code then crashes cinema 4D. Maybe I am doing it in the wrong function (tried in message,init)? Where do we have to set the second image?
