    installing numpy and pydicom in C4D
    5 Posts 0 Posters 799 Views
      On 19/11/2017 at 11:12, xxxxxxxx wrote:
      Hi everyone,
      I am trying to do some stuff with pydicom, a python extension that allows the loading of DICOM files, which are medical imaging files from CT and MRI scanners.
      To read the data I also need numpy.
      I have read some older threads about installing numpy, but I cant make heads or tails from it.
      I have no idea about wheels, eggs or whatnot.
      Can anyone provide the simplest way to install both those packages?
      Some sort of zip file, I can uncompress and drag into my preference/library/python.... folder
      here are links to pydicom
      docs:
      https://pydicom.readthedocs.io/en/stable/getting_started.html
      git:
      https://github.com/pydicom/pydicom
      thanks!
        On 20/11/2017 at 06:08, xxxxxxxx wrote:
        Hi Thanassis,
        such a rare visitor in our dark cave...
        Unfortunately from MAXON's side we do not support 3rd party packages/modules/libraries. I mean, of course you may use them, but we simply can't help with it. Terribly sorry!
        I guess, your best bet is currently Niklas, for example in this thread: Numpy Revisited for R18 (Simple)
          On 20/11/2017 at 17:32, xxxxxxxx wrote:
          Thanks Andreas, I'll bug Niklas.
            On 21/11/2017 at 08:43, xxxxxxxx wrote:
            I've added some instructions for build NumPy on Windows here:
            https://www.niklasrosenstein.com/post/2017-11-21-building-numpy-for-cinema4d-on-windows/
            You can find a number of pre-compiled NumPy versions here:
            https://public.niklasrosenstein.com/cinema4d/python/modules/
            @noseman
            If you're on Windows, grab the numpy-1.13.3-py2.7-win-amd64.egg  and open it with as a
            ZIP file (eg. using 7-Zip or rename it to .zip first). You can then simply copy & paste the numpy/
            folder to your preferences/library/python/packages/win64 directory.
            If you're on macOS, try the  numpy-1.11.0-py2.7-mac.zip (I did not compile 1.13.3 on macOS yet).
            It's basically the same story, only that is already is a .ZIP file and the numpy/  directory is one more
            directory lower.
            Not sure if this mac version still works on recent C4D releases, haven't tried it in a while.
              On 21/11/2017 at 09:46, xxxxxxxx wrote:
              Thanks niklas for your blog post!
              Very handy, didn't know about step 3, explain why I failed most of the time. So big thumbs up !!!
