    GeUserArea GetMinSize can't scale down
    3 Posts 0 Posters 602 Views
      On 02/11/2017 at 11:07, xxxxxxxx wrote:
      Hello, I'm facing to a weird problem where I can't scale down my GeUserArea but I can scale up.
      Here is my code which is very basic
      def Sized(self, w, h) :
          print "SIZED| w:{} - h:{}".format(w, h)
          self._w = w
          self._h = h
          self.LayoutChanged()
      def GetMinSize(self) :
          print "GETMINSIZE| w:{} - h:{}".format(self._w, self._h)
          return self._w, self._h
      My final goal is to dynamicly limit the min width size but can still be dynamic.
      Thanks in advance
        On 02/11/2017 at 12:01, xxxxxxxx wrote:
        Well, every time you size your userarea Sized is called, which sets self._w and self._h to the current size.
        While your GetMinSize returns these exact values. So, you cannot go less than your current size, since that's what you return as the minimal size. As a result, you can only resize larger.
        Your GetMinSize should return the actual minimal values and not the self._w, self._h which have been set by the Sized function.
          On 02/11/2017 at 13:08, xxxxxxxx wrote:
          Hoooo ok pretty stupid from me. Thanks solved.
