    Dirty when visibility or enabled changes
    3 Posts 0 Posters 549 Views
      On 20/10/2017 at 02:51, xxxxxxxx wrote:
      I have an object plugin and I want to detect when the Visibility (Editor or Rendered) or Enabled of the child  object changes?
      I am checking IsDirty in GetVirtualObjects(), but the child is not dirty when I change the Visibility or Enabled.
      dirty = child.IsDirty(c4d.DIRTY_MATRIX | c4d.DIRTY_DATA | c4d.DIRTY_CACHE)
        On 23/10/2017 at 22:14, xxxxxxxx wrote:
        Hi Pim, thanks for writing us.
        From a brief test I can't reproduce the issue you mentioned since the code below properly regenerates "new" geometry every time render/editor visibility is changed or the object is turned on/off.
          def GetVirtualObjects(self, op, hh) :
              if op is None or hh is None:
                  return None
              child = op.GetDown()
              if not child:
                  return None
              childDirty = child.IsDirty(c4d.DIRTY_MATRIX | c4d.DIRTY_DATA | c4d.DIRTY_CACHE)
              child.Touch()
              cache = op.GetCache()
              if not childDirty and cache is not None:
                  print "cache"
                  return cache
                  print "regenerated"
              sphere = c4d.BaseObject(c4d.Osphere)
              sphere.SetMl(child.GetMl())
              return sphere
        Maybe I didn't properly get your point?
        Best, Riccardo
          On 31/10/2017 at 00:52, xxxxxxxx wrote:
          Sorry, together with the answers in the other post, the issue is now solved and I guess you are correct.
          I took the wrong approach.
          -Pim
