    Using STL with CodeWarrior
    3 Posts 0 Posters 389 Views
      On 28/03/2003 at 07:02, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:   Windows  ; Mac  ;
      I'm using CodeWarrior under Windows to build a plugin for a Mac target, and having problems using STL.
      If I don't use the STL (Standard Template Library) then it compiles cleanly. My code doesn't need the math library functions (sin(), cos(), etc) but if I use them it still compiles cleanly, so the compiler is finding the maths header/library.
      If I add the line:
      #include <vector>
      to the top of the file prior to the 'c4d.h' include, then I get compiler errors saying that cos() and sin(), etc cannot be found. This applies even if I'm not using those functions.
      If I move the above include statement to after the 'c4d.h' include, I get a different error stating that 'offsetof' is being redefined.
      I note that the STL is not used at all in the SDK examples (which compile cleanly).
      So, there seems to be some nasty interaction between the '#include <vector>' and the '#include "c4d.h"', which means that I can't use the STL. This behaviour isn't limited to the vector container, either.
      Any comments, suggestions, etc?
      Cheers - Steve
        On 28/03/2003 at 10:30, xxxxxxxx wrote:
        This is how I do it:
            // xlentstl.h:
            #ifndef XLENT_STL_H
            #define XLENT_STL_H
            #undef offsetof
            #include <vector>
            #include <set>
            #include <algorithm>
            #endif
            // myalgorithm.cpp
            #include "c4d.h"
            #include "c4d_symbols.h"
            #include "xlentstl.h"
            void Function(BaseContainer& bc)
             using namespace std;
             vector<String> list;
        This compiled fine in CW8.
          On 28/03/2003 at 11:30, xxxxxxxx wrote:
          Aha! Yes, that works - thanks!
