    Plugin Specific Data not set
    4 Posts 0 Posters 565 Views
      On 13/10/2017 at 10:40, xxxxxxxx wrote:
      Our plugin has been saving data to the active document for a couple of years now without issue, however we recently had one client contact us where the data would not write/read.  This is happening on multiple of their workstations running Win10 and C4D v18.
      Here is the code we use to save and retrieve the information.
      > import c4d
      > plugin_ID=1000001 #tmp ID for testing
      > # WRITE
      > doc=c4d.documents.GetActiveDocument()
      > container=c4d.BaseContainer()
      > myString=container.SetString( 9111, "This is my string" )
      > doc[plugin_ID] = container
      > # READ
      > container=doc.GetDataInstance()
      > newString =container[plugin_ID].GetData( 9111 )
      > print ' STRING: %s' % newString
      This has been working successfully for multiple clients except this one specific client.  We also tried changing the read to this:
      > # READ
      > container = doc[plugin_ID]
      > newString = container.GetString( 9111 )
      This also produced the same result of no data read on their workstations... this does work on ours.
      We thought that there may have been a conflicting plugin id but couldn't find evidence of that.  Is there another reason that we are missing that would keep data from being saved to a document?
      On a side note the same client says that they do not have the issue in C4D v19.
      Any help would be greatly appreciated...
      Andrew
        On 16/10/2017 at 03:38, xxxxxxxx wrote:
        Hi and Welcome to the Plugin Cafe!
        This is a known issue that got introduced in R18.057 (R18 SP3). It was fixed in R19.024 (R19 SP1). Unfortunately there's no fix for R18.
        The operator [] gives corrupt/invalid containers and this also affects other functions returning containers.
        The workaround in R18.057 is to use GetContainer()/GetContainerInstance() instead.
        Note the IDs in the range reserved for development (1000001-1000010) should not be used to set data into a document's container.
        Because these IDs are only meant for testing and data should be saved into a document using a requested plugin ID[URL-REMOVED].
        Also, the IDs within the range 1000000-1001000 are reserved for special document's scene hooks.
          On 16/10/2017 at 11:25, xxxxxxxx wrote:
          Thanks Yannick! Glad to see I'm not crazy. 🙂
          All good on the plugin ID btw...  I just slugged that in for demo purposes.
          While we're on the container topic, what is the preferred read method:
          or
          Andrew
            On 17/10/2017 at 04:19, xxxxxxxx wrote:
            container = doc.GetDataInstance()
            or
            These lines does not perform the same operation.
            doc.GetDataInstance() returns the data container instance for the document. While doc[plugin_ID] returns the plugin_ID sub-container of the document data container.
            With the data container instance another line is needed to retrieve the sub-container.
            Note doc[plugin_ID] returns a copy of the sub-container so if it is changed, it must be assigned back.
            Using the [] operator in Python to access parameters is preferred because it is faster to write and more pythonic. Unfortunately it is broken in R18.057.
