    Adding object to In/Exclusion List
    4 Posts 0 Posters 736 Views
      On 05/10/2017 at 11:58, xxxxxxxx wrote:
      I'm trying to create a null and add it to an in/exclusion list. The list is in the user data of an xpresso tag. This will be run off of a script. I have this code so far:
      from c4d import gui, utils
          document = doc
          tagowner = doc.SearchObject('StageLightMaster')
          xtag = tagowner.GetFirstTag()
          LinkList = xtag[c4d.ID_USERDATA,1]
          NullMaster = c4d.BaseObject(5140)
          document.InsertObject(NullMaster)
          LinkList.InsertObject(NullMaster,1)
      I can run a count before and after the object is added and it seems to be running properly, but when I go to the list in the tag it is not updated to include the null. I read somewhere that I need to update the gui object for the changes to take place, but I'm not sure how to call it. Any help is greatly appreciated! Thanks!
        On 06/10/2017 at 02:05, xxxxxxxx wrote:
        Add
        xtag[c4d.ID_USERDATA,1] = LinkList
        Before your EventaAdd().
        If we go step by step in your program here is what happend.
        mport c4d
            #Get the obj
            document = doc
            #Get the tag
            #Get a copy in memory of xtag[c4d.ID_USERDATA,1]
            #Create in memory a new object an copy it to NullMaster
            #Insert The the object into the document
            #Insert the object into your linklist variable which is a copy in memory of the userdata
            #Trigger an event
        So as you see you only change value on memory so you need to push back into the object 😉
          Hi and Welcome to the Plugin Cafe forums!
          LinkList in your script (retrieved with xtag[c4d.ID_USERDATA,1]) is a copy of the actual in/exclusion user data.
          So it has to be assigned to xtag[c4d.ID_USERDATA,1], after inserting the null object, for the in/exclusion user data to be updated in the GUI.
            On 06/10/2017 at 05:40, xxxxxxxx wrote:
            Well you guys are just awesome! Thanks for explaining the logic behind the solution this helps me out tremendously.
