    Checking editor mode?
    4 Posts 0 Posters 548 Views
      On 26/03/2003 at 09:52, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      My first little plugin is mostly done, there's one little thing that I've worked around:
      Currently I've the following code in the plugin's GetState() method:
      var doc =GetActiveDocument();
      if (!doc) return NULL;
      var obj =GetActiveObject(doc) ;
      if (!obj || !instanceof(obj, PolygonObject)) return NULL;
      var polysel = obj->GetPolygonSelection();
      if (!polysel||polysel->GetCount()==0) return NULL;
      return CMD_ENABLED ;// ok, enable
      This enabled the plugin when there is a polygon selection.
      However, to prevent excessive flashing of the icon I actually I would like to enable the plugin when the editor is in polygon mode, not only when I actually have a selection.
      Any hints?
      Thanks a lot in advance!
      Kabe
        On 28/03/2003 at 10:36, xxxxxxxx wrote:
            doc->GetMode() == [CODE]Mpolygon
        [/CODE]
          On 28/03/2003 at 10:50, xxxxxxxx wrote:
          Mh, you realized that I was asking about COFFEE?
          Unfortunately that function is neither in the docs [which would be bearable] nor avalailable in the application [(9) Member not found].
          I'm using R8.1 with OS X
          Thanks for any clarification!
          Klaus
            On 28/03/2003 at 10:55, xxxxxxxx wrote:
            Sorry, then it's not possible.
