    Pressing Set button in Hair Constraint Tag
    3 Posts 0 Posters 615 Views
      On 30/08/2017 at 12:16, xxxxxxxx wrote:
      Hello! I'm trying to make a script that generates two nulls for a spline and attaches spline's first and last point to those nulls.
      In this topic Andreas tells to use CallButton() function, but I can't get this script to work.
      https://developers.maxon.net/forum/topic/9445/12661_clicking-set-button-of-constraint-tag-from-pygen
      The script is for Script Manager. You have to select spline object first and then run the script.
        selo = doc.GetActiveObjects(0)
        if len(selo) > 0:
            for o in selo:
                    select_points = o.GetPointS()
                    pc = len(o.GetAllPoints())
                    select_points.DeselectAll()
                    select_points.Select(0)
                    nulla = c4d.BaseObject(c4d.Onull)
                    if nulla is None:
                    nulla[c4d.NULLOBJECT_DISPLAY] = 2
                    nulla.SetAbsPos(c4d.Vector(o.GetPoint(0)[0],o.GetPoint(0)[1],o.GetPoint(0)[2]))
                    nulla.SetName("A")
                    doc.InsertObject(nulla)
                    aTag = o.MakeTag(1018074)
                    aTag[c4d.HAIR_CONSTRAINTS_TAG_ANCHOR_LINK] = nulla
                    c4d.CallButton(aTag, c4d.HAIR_CONSTRAINTS_TAG_SET_ANCHOR)
                    select_points.Select(pc-1)
                    nullb = c4d.BaseObject(c4d.Onull)
                    if nullb is None:
                    nullb[c4d.NULLOBJECT_DISPLAY] = 2
                    nullb.SetAbsPos(c4d.Vector(o.GetPoint(pc-1)[0],o.GetPoint(pc-1)[1],o.GetPoint(pc-1)[2]))
                    nullb.SetName("B")
                    doc.InsertObject(nullb)
                    bTag = o.MakeTag(1018074)
                    bTag[c4d.HAIR_CONSTRAINTS_TAG_ANCHOR_LINK] = nullb
                    c4d.CallButton(bTag, c4d.HAIR_CONSTRAINTS_TAG_SET_ANCHOR)
                    o.InsertTag(c4d.BaseTag(1018068))
      I made similar script that uses CallButton function with Spline Dynamics tag to set fixed points and it works. Weird...
        On 31/08/2017 at 05:51, xxxxxxxx wrote:
        this got discussed just recently. Please have a look at CallButton Won't Work on new Tags.
          On 31/08/2017 at 08:05, xxxxxxxx wrote:
          Thank you Andreas. Now it works!
