    Preference Sub-Container references
    3 Posts 0 Posters 651 Views
      On 10/08/2017 at 00:19, xxxxxxxx wrote:
      Hey Guys,
      Bit of a beginners question, but i'm looking to find out where i can get more info on getting and setting global preferences - in particular accessing the sub-containers.
      I am referencing this thread: GetWorldContainer to change preferences
      In it Andreas kindly explains how to access the net-render sub-container:
        ma = c4d.GetWorldContainerInstance()
        np = ma[c4d.PREFS_PRI_NET]  # get the net render sub-container
        np[c4d.PREF_NAME] = "NewName"
        ma[c4d.PREFS_PRI_NET] = np  # store the changed container to preferences
      I would like to access the preferences > files > autosave sub-container. However, if someone could point me in the direction of where to find a list of all the different subcontainers, or how to access them, that would be amazing (knowledge is power and all that 😉)
      Cerac
        On 10/08/2017 at 03:07, xxxxxxxx wrote:
        In fact, most preferences are stored directly into the world container.
        The WPREF_AUTOSAVE_ IDs for the Files->Auto-Save preferences can be found in the C++ SDK docs here.
        Here's some code:
        prefs = c4d.GetWorldContainerInstance()
        prefs[c4d.WPREF_AUTOSAVE_ENABLE] = True   # Enable autosave
        prefs[c4d.WPREF_AUTOSAVE_MIN] = 2         # Autosave each 2 minutes
        prefs[c4d.WPREF_AUTOSAVE_LIMIT_TO] = True # Limit number of autosave
        prefs[c4d.WPREF_AUTOSAVE_LIMIT_NUM] = 20  # To 20 copies
        # Autosave destination user/custom path
        prefs[c4d.WPREF_AUTOSAVE_DEST] = c4d.WPREF_AUTOSAVE_DEST_USERDIR
        prefs.SetFilename(c4d.WPREF_AUTOSAVE_DEST_PATH, "dir/to/dest/path")
        Note c4d.WPREF_AUTOSAVE_DEST_PATH has to be set with SetFilename() into the container.
          On 10/08/2017 at 05:09, xxxxxxxx wrote:
          That's great Yannick, thanks ever so much, I always forget to cross check in the C++ SDK.
          Nice one for pointing me there!
