    Obaselist Group in MaterialData .res
    2 Posts 0 Posters 394 Views
      On 08/08/2017 at 05:50, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hello.
      I have MaterialData and inside its res file I have used
      INCLUDE Mbase;
      GROUP Obaselist {
      	//Params
      GROUP ParamGroup1 {
      	//Params
      GROUP ParamGroup2 {
      	//Params
      I have some parameters and I add these parameters in ParamGroup2 via code using description->SetParameter e.t.c.
      EDIT:
      The problem is that these parameters are added in Obaselist instead of ParamGroup2.
      What  is included in INCLUDE Mbase; and in GROUP Obaselist ?
      It appears that I have ID conflicts with the included res files.
      I have checked obaselist.h and mbase.h files but I didn't find any conflict there.
      Thank you for your time.
        On 09/08/2017 at 09:40, xxxxxxxx wrote:
        it's a bit difficult to judge without seeing the code you use to insert the parameter.
        Here's how it works for me:
        	Bool GetDDescription(GeListNode* node, Description* desc, DESCFLAGS_DESC& flags)
        		if (!desc->LoadDescription(node->GetType()))
        			return false;
        		const DescID groupID = DescLevel(ParamGroup2, DTYPE_GROUP, 0);
        		const DescID cid = DescID(DescLevel(myparamid, DTYPE_STRING, 0));
        			BaseContainer bc = GetCustomDataTypeDefault(DTYPE_STRING);
        			bc.SetString(DESC_NAME, "My String Param");
        			desc->SetParameter(cid, bc, groupID);  // don't forget to provide correct group ID here
        		return SUPER::GetDDescription(node, desc, flags);
