    Using char key modifiers
    3 Posts 0 Posters 487 Views
      On 04/08/2017 at 19:34, xxxxxxxx wrote:
      I made a simple script to help easily rotate an object by 90 degrees, the axis is determined by a predefined key ("1", "2", "3") being held prior to script execution.
      This seems to work well, I tried it with the script mapped to the ` key.
      I wanted to check if it is written in the best way, especially considering where I have put my undo steps:
      from c4d import gui
      def checkPressed(k) :
          # Check any one key
          bc = c4d.BaseContainer()
          if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, k ,bc) :
              if bc[c4d.BFM_INPUT_VALUE] == 1:
                  print "%s PRESSED" % unichr(k)
                  print "%s NOT PRESSED" % unichr(k)
                  return False
      def rotat(obj, r) :
          doc.StartUndo()
          doc.AddUndo(c4d.UNDOTYPE_HIERARCHY_PSR, obj)
          if r is "x":
              newMatrix = obj.GetMl() * c4d.utils.MatrixRotX(c4d.utils.Rad(90))
          elif r is "y":
              newMatrix = obj.GetMl() * c4d.utils.MatrixRotY(c4d.utils.Rad(90))
          elif r is "z":
              newMatrix = obj.GetMl() * c4d.utils.MatrixRotZ(c4d.utils.Rad(90))
              print "error"
          obj.SetMl(newMatrix)
          doc.EndUndo()
        obj=doc.GetActiveObject()
        if obj is None:
              pass
        if checkPressed(ord('1')) :
          rotat(obj, "x")
        elif checkPressed(ord('2')) :
          rotat(obj, "y")
        elif checkPressed(ord('3')) :
          rotat(obj, "z")
        On 05/08/2017 at 05:57, xxxxxxxx wrote:
        Update (https://github.com/NNNenov/C4Dhandy/blob/master/scripts/functional/Turn90/Turn90.py )
            # Check any one key
                    return False
        def rotat(obj, r) :
            doc.StartUndo()
            if r is "x":
                newMatrix *= c4d.utils.MatrixRotX(c4d.utils.Rad(90))
            elif r is "y":
                newMatrix *= c4d.utils.MatrixRotY(c4d.utils.Rad(90))
            elif r is "z":
                newMatrix *= c4d.utils.MatrixRotZ(c4d.utils.Rad(90))
            doc.EndUndo()
          #obj = doc.GetActiveObject()
          objs = doc.GetActiveObjects(0)
          if len(objs) == 0:
                pass
          for obj in objs:
                rotat(obj, "x")
                rotat(obj, "y")
                rotat(obj, "z")
          On 07/08/2017 at 02:58, xxxxxxxx wrote:
          I see no problem with the position of the undo step.
          In regards to "best way", I leave any discussion on optimization up to the community.
