    Vector
    2 Posts 0 Posters 253 Views
      On 04/07/2017 at 01:02, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hello.
      In .res files you can have VECTOR as parameter type. That adds 3 spinners for X,Y,Z.
      Can I have a VECTOR2 parameter ? I need only X and Y.
      I found a Vector2dCustomGui parameter. Is there any example with it ?
      Thank you.
        On 04/07/2017 at 01:27, xxxxxxxx wrote:
        there is no build-in 2D vector type in Cinema 4D. The 2D Vector Field Vector2dCustomGui is a custom GUI for the standard 3D vector type. It is used for example in the MoText's "Axis" parameters. Or you can simply create a "Vector" user data with the "2D Vector Field" interface.
        If you want to have a pure 2D vector parameter type you might have to create it yourself using a custom data type based on CustomDataTypeClass and a custom GUI based on CustomGuiData / iCustomGui.
