    DrawBitmap and AllowAlpha
    6 Posts 0 Posters 834 Views
      On 29/06/2017 at 03:03, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hello.
      I have a GeUserArea and I inherit its DrawMsg to draw 2 bitmaps on top of each other.
      First, I use DrawBitmap to draw the background image and then I draw the topmost bitmap which requires BMP_ALLOWALPHA .
      The problem is that using BMP_ALLOWALPHA shows the background color DrawSetPen(COLOR_BG) instead of the background image.
      How can I fix that ?
      Thank you.
        On 29/06/2017 at 11:30, xxxxxxxx wrote:
        As far as I know, the only solution is to use a GeClipMap. However, that class does only support direct
        blitting, without scaling.. Doing the scaling in C++ is pretty darn slow on bigger images and causes my
        dialog to lag horribly when the user area is resized.
        I'd love to know if there was actually a way to use DrawBitmap() with proper alpha support, too.
          On 30/06/2017 at 03:11, xxxxxxxx wrote:
          Hello and thank you very much for your answer.
          So basically, I will set the bitmap to a GeClipMap and draw the stored bitmap, correct ?
          Inside DrawMsg:
          BeginDraw();
          BaseBitmap* base_bitmap = clip_map->GetBitmap();
          DrawBitmap(base_bitmap, ........);
          EndDraw();
          I couldn't find any reference in the examples.
          Thank you.
            On 30/06/2017 at 03:29, xxxxxxxx wrote:
            You would need to create a GeClipMap on which you combine the two BaseBitmaps to get your
            final "image" that you want to draw on the GeUserArea. Something like
            AutoAlloc<GeClipMap> map;  // cache that somewhere maybe
            map->BeginDraw();
            map->Blit(image1, ...);
            map->Blit(image2, ...);
            map->EndDraw();
            BaseBitmap* final = map->GetBitmap();
            userArea->DrawBitmap(final, ...);
              On 30/06/2017 at 03:56, xxxxxxxx wrote:
              I don't think this is going to work because my background image is scaled since it is drawn in a GeUserArea with DrawBitmap.
              I have tried using Init (BaseBitmap *bm, BaseBitmap *alpha_channel) passing the image and a black/white image indicating the transparent regiong but it didn't work 😞
              So it appears that my only solution is to use a fixed background and use GeClipMap's blit, right ?
              Thank you.
                On 06/07/2017 at 09:27, xxxxxxxx wrote:
                I'm sorry, we haven't come up with any other idea here.
