    selection order and shift-select
    5 Posts 0 Posters 905 Views
      On 25/06/2017 at 17:04, xxxxxxxx wrote:
      Silly question:
      I'm trying to retrieve selected objects in order.  This normally works fine if they are picked individually, but if I shift-select a range in the Object Manager, the list is not in order.
      selected = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_SELECTIONORDER)
      order in Object Manager, shift selected top-to-bottom:
      Cube.7
      Cube.6
      Cube.5
      Cube.4
      Cube.3
      Cube.2
      Cube.1
      Cube
      order of selected list:
      Cube.7
      Cube.1
      Cube.2
      Cube.4
      Cube.3
      Cube.5
      Cube.6
      Cube
      Seems to always get the first and last correct, but not the ones in between.
      Hopefully I just missed something obvious. C4D R18.048
        On 26/06/2017 at 09:15, xxxxxxxx wrote:
        I was able to reproduce the issue, it also occurs with rectangle selection. I need to investigate a bit further, why it's not working.
          On 26/06/2017 at 17:51, xxxxxxxx wrote:
          Thanks very much Andreas!
            On 27/06/2017 at 06:00, xxxxxxxx wrote:
            Hi Kevin,
            I can confirm this is a bug. Unfortunately I can not give any estimates, when this will be fixed.
              On 27/06/2017 at 06:33, xxxxxxxx wrote:
              No worries, thanks for looking into it!
              Would you have any tips on detecting a shift or box select, so I could re-order them from within my script?  The first and last seem consistent, so I could use those to bound my hierarchy search.
