    Fill ShaderData preview
    3 Posts 0 Posters 398 Views
      On 15/06/2017 at 02:54, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hello.
      I have a ShaderData plugin that I need to set value to its preview.
      I know I Have to use InitRender and FreeRender to setup and destroy my data.
      The problem is that Output method feels a little bit slow since I have to set the value for each UV separately. Also, I use an external lib to calculate the shader that can be done in the InitRender.
      Can I avoid Output and simply set the shader preview by copying the base bitmap ? Is there any message to which I have to respond to achieve that ?
      Thank you very much for your time.
        On 16/06/2017 at 02:20, xxxxxxxx wrote:
        no, this is not possible. You can of course create the bitmap in InitRender() and then only sample (basically copy pixels) the bitmap in Output().
          On 16/06/2017 at 05:16, xxxxxxxx wrote:
          Thank you very much Andreas.
