    Access BodyPaint Layer (BPLayer) Opacity
    4 Posts 0 Posters 653 Views
      On 11/05/2017 at 23:20, xxxxxxxx wrote:
      Cinema 4D Version:   R17, R18
      Is there any way to access the opacity of a BodyPaint layer? I have tried reading the ID_PAINTLAYER_OPACITY value from the BaseContainer as well as GetParameter but it doesn't seem to work.
      For reference here is where the ID_PAINTLAYER_OPACITY is defined.
      http://www.gamelogicdesign.com/Description/Node?containerName=BPlayer
      And although I haven't tried it yet, since opacity didn't work, I would also like to access ID_PAINTLAYER_BLEND as well.
      Ideally I would like to be able to both read and write these values.
      Kent
        On 15/05/2017 at 03:02, xxxxxxxx wrote:
        at least in R18, setting ID_PAINTLAYER_OPACITY seems to work fine:
        // get texture
        PaintTexture* texture = PaintTexture::GetSelectedTexture();
        if (!texture)
         return false;
        // get layer
        PaintLayer* layer = texture->GetFirstLayer();
        if (!layer)
         return false;
        // change opacity
        GeData data;
        layer->GetParameter(ID_PAINTLAYER_OPACITY, data, DESCFLAGS_GET_0);
        Float opacity = data.GetFloat();
        opacity = opacity* 2.0;
        layer->SetParameter(ID_PAINTLAYER_OPACITY, opacity, DESCFLAGS_SET_0);
        // set blend mode
        layer->SetParameter(ID_PAINTLAYER_BLEND, LAYER_MULTIPLY, DESCFLAGS_SET_0);
        EventAdd();
          On 15/05/2017 at 14:23, xxxxxxxx wrote:
          I have only been testing with R17 so far. Great to know that its working in R18. My code was doing the exact same thing as what you have there. I will double check this all again, but its good to know that its working for you in R18.
          Cheers.
            On 26/05/2017 at 18:14, xxxxxxxx wrote:
            Just a follow up on this. Totally my own fault. I was missing an EventAdd();
            Silly mistake on my part. Thanks for testing.
