    script syntax help
    3 Posts 0 Posters 511 Views
      On 02/05/2017 at 06:16, xxxxxxxx wrote:
      Hi guys,
      sometimes I use the Script log to see what a command syntax looks like, and usually fail to create a Python script out of it.
      For example, using:
          prefs(465001620)[c4d.PREF_INTERFACE_CENTEROBJECT]=True
          prefs(465001620)[c4d.PREF_INTERFACE_CENTEROBJECT]=False
      turns the "Create New object at View Center" on and off.
      How would I create a script that toggles between states, with the icon being Active (blue) when it's on and grey when it's off?
      just pasting the code in a script gives me an error:
        File "'scriptmanager'", line 11, in <module>
        File "'scriptmanager'", line 7, in main
      NameError: global name 'prefs' is not defined
      Noseman
        On 02/05/2017 at 07:00, xxxxxxxx wrote:
            interface = c4d.plugins.FindPlugin(465001620, c4d.PLUGINTYPE_PREFS)
            interface[c4d.PREF_INTERFACE_CENTEROBJECT] = not bool(interface[c4d.PREF_INTERFACE_CENTEROBJECT]) #toogle
        For the state take a look at my video here (in french)
        Or look at this post where you have everything you need for doing it https://developers.maxon.net/forum/topic/423/13564_plugins-in-plugin-or-icons&PID=53811#53811
        Btw I wanted to say a big thank you!
        You are one of the guy who inspire me about doing pythonic stuff. So thanks for your love of c4d and all your share !
          On 02/05/2017 at 10:09, xxxxxxxx wrote:
          Thank you so much for your help.
          I was trying to help out a user on CG Society.
          I'm going to post your script alongside another solution.
          Also, I'm glad I could inspire you to push the limits of C4D... keep up the great work!
