    Multi key shortcuts
    3 Posts 0 Posters 448 Views
      On 01/05/2017 at 06:16, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hi again,
      Working on a plugin project consisting of multiple plugins (tools and commands) which I wanted to see listed in a particular order in the plugin menu. For this I used the "#$n" in the stringtable, with increasing values for n, according to the requested sorting.
      I then assign multi key shortcuts to the different plugins, all sharing the same first key (example Q~S, Q~A, Q~D, ...) using the customize command.
      The "#$n" is shown in front of the plugin string, in the multi-key popup window when I press "Q".
      While in the menu, the "#$n" isn't shown.
      Is there something I am missing in order to not show these "sorting" string portions in the multi-key popup window? Or is this a limitation/feature/bug?
        On 03/05/2017 at 02:51, xxxxxxxx wrote:
        Hi C4DS, thanks for writing us.
        I've replicated your behavior and I confirm that you've hit a bug. I'll keep you updated when it will be fixed.
        Cheers, Riccardo
          On 03/05/2017 at 03:50, xxxxxxxx wrote:
          Thanks for the feedback.
