    Tag out of sync problem
    4 Posts 0 Posters 623 Views
      On 25/04/2017 at 03:02, xxxxxxxx wrote:
      Hi 🙂
      I am sorry for asking something this simple, haven't done much scripting but I have a really simple script, that creates a NormalTag on the selected objects. It's working fine on primitives but not on real geometry.
      It crashes C4D if I execute the script on a 3D mesh with the error: Object "ObjectName" - Tag 5711 not in sync. Any hints on how to fix it and what I am doing wrong?
      Thank you in advance!
          doc.StartUndo()
          objs = doc.GetActiveObjects(1)
          if not objs:
              gui.MessageDialog('No objects selected.')
          for i in objs:
              tag = i.MakeTag(c4d.Tnormal)
              doc.AddUndo(c4d.UNDOTYPE_NEW, tag)
          doc.EndUndo()
        On 25/04/2017 at 03:37, xxxxxxxx wrote:
        normalTag are special variable tag since they need parameter for init (basicly the number of polygons)
            doc.StartUndo()
            if not objs:
                c4d.gui.MessageDialog('No objects selected.')
            for obj in objs:
                normalTag = op.GetTag(c4d.Tnormal)
                if normalTag:
                    print 'tag already exist'
                    continue
                #if there is no tag initg:
                poly_cout = obj.GetPolygonCount()
                normalTag = c4d.NormalTag(poly_cout)
                #Assign
                doc.AddUndo(c4d.UNDOTYPE_NEW, normalTag)
                obj.InsertTag(normalTag)
            doc.EndUndo()
        For manipulate data I suggest you to read the c++ sdk wich is way mroe relevant than the python one on this topic.
        https://developers.maxon.net/docs/cpp/2023_2/page_manual_normaltag.html
          On 25/04/2017 at 04:11, xxxxxxxx wrote:
          Thanks for the super fast reply and the help!
          Will definitly read up on this 🙂
            On 26/04/2017 at 10:06, xxxxxxxx wrote:
            Hi Dimitri,
            Glad to see, your question is already answered. Again, thanks, gr4ph0s!
            Since you are new here, I was just chiming in to provide the link to our Development Blog, as I did in the other thread. So nobody feels left behind...
