    GetClone() or no GetClone()?
    4 Posts 0 Posters 706 Views
      On 18/04/2017 at 04:58, xxxxxxxx wrote:
      When I use SendModelingCommand( command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
      I thought that I should use: list = [op.GetClone()],
      but that does not work.
      I must use list = [op],
      So without getting a clone of the object (in this case a MoGraph Cloner)?
      Am I missing something?
      -Pim
        On 18/04/2017 at 08:29, xxxxxxxx wrote:
        Can be stupid but GetCLone return an obj wich is into memory but not into the document. SO have you tried to insert it before run sendmodelingcommand?
          On 19/04/2017 at 01:41, xxxxxxxx wrote:
          Hi Pim,
          gr4ph0s is right. The object is cloned but it has to be inserted into the document for SendModellingCommand().
          For MCOMMAND_CURRENTSTATETOOBJECT the object passed does not need to be cloned because the function returns the converted object.
          But other commands like MCOMMAND_MAKEEDITABLE change the input object so you have to decide to pass an original or a cloned object in a temporary document.
            On 19/04/2017 at 05:04, xxxxxxxx wrote:
            Ok, clear thanks.
